Post your latest oil change
Vehicle = GM-Holden (Opel) Astra (AH)
OCI = 7,400 km / 4,600 miles / 6 months
Out = Penrite SAE 30, monograde mower oil (API SG)
In = Nulon 5W30 Long-Life full synthetic (Dexos1-Gen2)
Filter is Valvoline V06 with synblend media, let it ride a bit longer.
Vehicle = GM Holden Astra (AH)
OCI = 11,700 km / 7,270miles / 11 months
Out: Nulon 5W30 full synthetic (Dex1-Gen2) + Valvoline V06 filter.
In: Gulf Western 10W30 semi-synthetic (API SP & ILSAC GF-6A) + Cooper WZ154 filter.
2016 Elantra 125,000 miles [original engine still runs], drained 2.2 litres of oil out, it was at the add mark and if I waited, I probably could have got more out. No filter change, 5,100 miles on old oil from November.
In - 2.4 litres Penzoil Platinum 5W20 and 0.9 litres SuperTech Euro 5W40. Probably a little over full now. It should make it until fall.
2001 Suburban 5.3 213K miles
3 month/3500 mile OCI "Severe Service" !!! I do lots of short trips/idling and live in the HOT SOUTH !! Gotta get ready for BOILING summer months !!
Out: Castrol Magnatec 10W-30
In: Delo 400 XLE blend 10W-30 1 Gallon+1qt rislone Hy-per Lube+1 QT Castrol Magnatec 10W-30
Note: Left fairly new "oLd SkOoL" wire mesh XG filter only on 2nd OCI ;)
2004 Toyota Camry 2.4 I4 288,367 miles. Changed about 300 early just because it was really dirty and it’s already used a quart so went ahead and done it while I had some free time. We do 3,000 mile oil changes and it uses a quart about every 2,200 miles or so.
Out 5 quarts of Valvoline High Mileage Synthetic Blend MaxLife 5W-30
Off: Fram PH4386
In: 5 quarts of Valvoline High Mileage Synthetic Blend MaxLife 5W-30
On: Fram PH4386
I have about 4 more of the PH4386 filters left that I found on clearance at Walmart. After that I’ll probably use Toyota F1 on it as I can get those cheap with my employee discount. Got the oil through work too but will be buying it at Walmart now mostly as when I request high mileage oil at work they insist on getting it at Auto Plus which only has single quarts of it that run about $7 a quart with our discount. Probably will pick up more when I go to Walmart tonight if they have it cause they have been out of all high mileage and 5W-30 anything.
That's a nice oil, I like Valvoline semi-synthetic oils like MaxLife and DuraBlend.
I've used a lot of Valvoline DuraBlend 10W40 (SN & A3/B4) myself. Back a few years ago, it was the bulk oil used by the local independent garage workshop around here. In Australia semi-synthetic oils are significantly cheaper to buy compared to full synthetic oil, so they get a lot of uptake. Especially the heavier 10W40 with both API and ACEA specs, everything from a Ford to a Toyota to a old Mercedes Benz would run it. When I called up Valvoline years ago, they indicated it was about 30% synthetic. Now days a garage workshop would be required to keep a menagerie of different OEM spec synthetic oils.
I've just started using a local oil Gulf Western, I picked up a semi-synthetic 10W30 (SP & GF-6A) on sale at $10 for a 5L jug. A typical full synthetic when on sale would be around $50 a jug. Big difference.
2001 Dodge Ram 2500 diesel,
577715 miles, 14679 miles OCI
Out: Mobil Delvac 1300+Redline oil additive, Fleetguard LF16035 filter
In: Shell Rotella T6 5w40, Fram Ultraguard XG39076 filter
Had to really dig into the Post Your Latest Oil Change thread to find the previous oil change on this truck.
July 6, 2019. When I was still hot-shotting trailers. I ran with this oil in it until I retired the truck in October, 2019. Since then it has sat around a lot and has only been driven 200-300 miles. I finally started feeling bad and treated the old girl to an oil change. I should drive her more to keep her exercised.
Friend's 2013 Toyota Highlander 2.4L
148,705 miles
OCI: 6 months & 5,445 miles
Out: Cam2 Superpro Max 5w-20 synthetic blend, Toyota filter
In: same oil, Fram CH9972 filter
I like this oil and wish it was easier to find locally.
148,705 miles
I've seen it at local gas stations and my local independent Carquest carries it same price as the Fram branded oil.
