Post your latest oil change
2014 Subaru Forester 6MT 2.5L NA
ODO: 110,151
Consumed: ~1.5 qt
Top up: 1.0 qt
Miles on oil: 110,151 - 106,036 = 4,115
Estimated hours on OCI: 4,115/42 = 98
Out: 5 quarts mix (5 quarts Supertech 20w-50 + 4 quarts Quaker State Euro 5w40 + 1 qt ETO2197)
In: 5.5 quarts blend (3 quarts Supertech 20w-50 + 2 quarts Traveller SAE 40 + 4 quarts Quaker State Euro 5w40 + 1 qt ETO2197)
Off: XG3593A
Estimated hours on filter: 62 + 98 = 160
Miles on filter: 2,602 + 4,115 = 6,717
On: XG7317
Decided to change when the blot test was showing overall blot darkening, plus an inner halo. I am tending to just change the oil when it gets this way and is clearly dark from a dipstick wipe as it seems to be a simplest approach...Very slightly lower consumption this OCI. Did an alcohol flush before draining--poured in 12oz when the engine was already warmed, turned it on and ran for 30 seconds, turned it off, and drained.
10 qt sump??
2011 Sorento 3.5 126xxx
Out:
5w30 mag1 synthetic & beck arnley filter
12k OCI (roughly 16 months, alot longer then I wanted)
In:
VegaLube 5w30 synthetic & Beck arnley
Will be about 7500k oci
2019 Sorento 2.4 22xxx
Out: no idea and OEM filter
4k OCI but wanted to put synthetic in
In:
5w20 Castrol synthetic & Fran
Will be 5-6k OCI mostly all short mileage alot of it with car barely warming up
2012 Silverado 5.3 with 160k on body 40k on replaced motor
Out: 6 qts 5w30(no idea) and AC Delco filte
In: 6qt 5w30 napa brand + KN filter
Had to screwdriver off the old filter, I didn't have a cap that fit the filter and no room for my adjustable to grab it, whichever engineer placed that filter there is an idiot , hence why I put the KN on to make it easy for the poor soul who changes it next
SIL’s 2019 Dodge Durango V6
117,314 miles on vehicle
12,579 miles on this OCI, OLM 0% probably for awhile too.
Out: Mobil Full Synthetic 5w20 & Wix WL10010
In: Exact same as above
Only about 5 quarts came out after it drained hot for about 45 minutes while I rotated tires and checked the brake pads. Probably burned some during that extended change period. Told brother he’s not very bright letting it go that long🤦‍♂️
2020 Honda Accord EX, 21,659 miles
7k OCI
Out: Pennzoil Platinum 0W20, ACDelco PF2057
In: same
