Post your latest oil change
2020 Chevrolet Equinox 1.5 turbo
21,147 on unit
4,322 on the oil
33% left on oil maintenance minder
Out: Kirkland 0W20
Out: ACDelco PF64
In: Castrol 5W20 EP
In: ACDelco PF64 12706595 (new version)
Dad's car needed a tire rotation, so I said what the hell. Car doesn't even need to be jacked to do the OC. Castrol EDGE Extended Performance 5w20 was free and came from the Walmart glitch days. $6 for the filter on amazon. Cheapest OC ever.
2011 Ford Escape V6 w/66,142 miles. Did a needed oil (& transmission fluid) change, before the long move to Kingman, Arizona. OCI was approximately 4500 or so miles, all of which were driven in a 2 month span.
OUT: Mobil 1 5W-20 & unknown filter (Auto dealer changed before I bought the car.)
IN: Valvoline MaxLife Full Synthetic 5w20 & VO-88 filter
Transmission was changed with Maxlife ATF at the same time. Car runs and shifts much better.
2020 Honda Accord EX
14,750 miles
OCI unknown, oil monitor at 10%
Out: Valvoline syn 0w20, VO-106 filter
In: Pennzoil Platinum 0w20, ACDelco PF2057
2018 VW Atlas w/3.6 VR6. ~35.5K on odo, ~5K on oil. No consumption.
Out: 5.5 qts Liquimoly Leichtlauf High Tech 5W40, 0.3 qt Supertech 5W30 HM conventional, 0.7 qt Castrol Edge 5W40 (left over catch-all this time), Ceratec, Mahle filter, drain plug
In: 4 qts Mobil 1 5W40 Euro, 1 qt Liquimoly Leichtlauf High Tech 5W40, 1 qt Quaker State Ultimate Durability Euro 5W50, Mahle filter, drain plug
I dig the bastard mix for the wookie. Well done, sir.
The kids 24v 2.8 VR6 Jetta got another drain & fill a couple weeks ago. 5200mi on oil, 130k on the motor.
Out: Fram/Amalie 5w40 + RT6 5w40 and Mahle filter
In: 5qt Fram/Amalie 5w40 + 0.5qt RT6 5w40 and Mann Filter
No consumption and the UOA came back decent.
My 2019 Chevrolet Silverado 1500 LD LT with the Gen V Ecotec3 L83 5.3 liter V-8
Odometer reading: 57,293 miles
OCI: 4,502 miles
Oil Out: 8 quarts of Providence(Rural King house brand) 0w20
Oil Filter Out: AC Delco PF63
Oil In: 4 quarts of Mobil 1 Extended Performance 0w20 and 4 quarts of Mobil 1 Advanced Fuel Economy 0w20
Oil Filter In: Fram TG10575
No oil consumption whatsoever during entire run. About $25 for the oil thanks to the Mobil 1 rebate and $10 for the oil filter. $35 total for another 5000 mile run isn’t too shabby at all.
Just got home from the cottage, the maintenance app on my Infiniti showed I had 48 kilometres left for the oil & filter. Did both before the oil cooled down. Pennzoil Platinum 0w20 out and same in, Mahle OC711 out and in. Cabin Filter too.
2014 Subaru Forester 6MT 2.5L NA
ODO: 90,578
Estimated hours on oil: 2,929/42 = 70
Miles on oil: 90,578 - 87,649 = 2929
Out: 3 qt (Quaker State Euro 5w-40 (mixed with 1 qt of Rislone High Mileage Engine Treatment 4102)
In: 3 qt of leftover 4:1 Delo XLE 15w40 : Mobil 1 5w30 (just above top marker of dipstick)
Off: none; starting round 2 for XG7317
Estimated hours on filter: 70
Miles on filter: 2,929
On: N/A
Car consumed about a pint at first, and Quaker State Ultimate Durability HM 5w30 replaced it's volume. It consumed about another pint before I decided that I would go the route of standardizing a flush as part of the OCI. If the car consumes a full quart, then that volume ought get replaced with 4102 and oil changed. If it does not consume that volume, then the oil will remain in the sump until the end of the OCI, which will be at most 120 hours before doing an ending flush. So, I decided that I would change it at 3k, and extracted half a quart of oil before putting in a quart (2 pints) of Rislone 4102. Drove that for 3.6 hours the next day before changing it. I was not able to extract all the oil, but I can't say that that is a problem. Quaker State Euro should have a starting TBN of 12 (the mixture being ~11.5), and 70 hours on the oil should not be dragging that down much. This mix should still be good for 100 hours (ideally).
At this point, I've decided to come down to 15-20% max E85. Car does run smoother with at least this amount.
ODO: 93,550
Estimated hours on oil: 2,972/42 = 71
Miles on oil: 93,550 - 90,578 = 2,972
Out: Mixture of Delo XLE, Mobil 1 5w30, and Quaker State Euro (+ the 1 pint residual Rislone 4102)
In: 1 gallon Redline 10w40 and 1.5qt Mobil 1 Extended Performance High Mileage 5w-20
Off: XG7317
Estimated hours on filter: 70 + 71 = 141
Miles on filter: 5,901
On: XG7317
Car consumed 1 quart by 2000 miles. Consumption doesn't match rpm from what I can tell now. Topped up 20oz and kept on going. Used Lubegard engine flush prior to oil change. How would I describe the old oil? Hmm, well I poured it in the midday, bright sun, and I could barely see through it when it was a wispy drizzle. I would call that done. It was about as loaded as I have seen my old 2GRFE when it was at 8,000 miles on Valvoline MaxLife. While I was under, I noticed some oil weeping from the timing cover, which uses FIG. The valve cover gaskets also look like they are weeping, but they don't show any cracks while I was wiping it all away. I would be happy to say that the weeping was severe, as that's the better of two problems, but the weeping is not severe enough (in my investigative reasoning) to account for the missing quarts I get in the OCIs. I took the skidplate/splashpan off the bottom and there wasn't any oil visible on it (nor exhaust, or anywhere under the car). I don't know what the Redline may do to FIG at this state, hurt or help. I am anticipating that it will need to be replaced. It may go well with a pretty large service that includes a litany of things. I still like this car, but I wish it was a little bit more bulletproof. I don't know how long of an OCI I'll go at the moment.
2016 Toyota 4Runner: 33,378 miles, (3,342 miles on oil, 10,943 miles on filter (2 OCIs). The oil was in service from 7/2/20 to 3/17/21. The filter was in service from 3/13/19 to 3/17/21.
Out: NAPA 0w20, Toyota 04152-YZZA5 (2 OCIs)
In: 5 quarts of Valvoline modern engine 0w20 + 1.5 quarts of Napa full synthetic 0w20, Toyota 04152-YZZA5. I used a Toyota 90430-12028 crush gasket on the engine oil drain plug.
I drained the front and rear differential fluid (factory fill) and refilled with synthetic 75w90. The transfer case fluid looked really good through the fill hole so I left it alone for now. I had intended to only inspect the rear diff fluid and check the level, but the fluid looked pretty bad when I pulled the fill plug so I went ahead and changed it. The front diff looked much better than the rear but I went ahead and changed both while I was at it. I also sucked out the PS fluid reservoir and refilled it with Supertech Mercon V (calls for Dexron III). This is the first time the PS fluid has been touched on this car, I intend to evacuate and refill the PS reservoir at each oil change from now on.
38,683 miles.
Out: ^ drained the oil, left the filter on.
OCI: 5,305 miles (3-17-21 to 9-23-21)
In: 5 quarts of VME 0w20 + 1 quart of VME 5w30. I sucked out and refilled the PS fluid reservoir again with ST Mercon V.
2016 LML Duramax 3500HD
Out: ^
OCI: 6,525 miles, 623.5 Hours (OLM @ 2%) (10-9-20 to 3-28-21)
In: Mobil Delvac 1300 Super 15w40, Carquest 84202 (made by Baldwin)
The truck has 66,728 miles and 4,948.5 engine hours.
I went ahead and changed out that TP3012 fuel filter for the correct TP3018. The fuel filter life remaining was 79%.
I flushed the power steering/hydro boost with AutoZone PS fluid. I ran a gallon of fluid through and topped it off. I’ve been noticing a slight whine on turns at low speed, the PS fluid change seems to have resolved that for now. I have been extracting and refilling the reservoir at each oil change for the last few years but that only removes about 8oz of fluid at a time. View attachment 51473
Out:^
OCI: 5,371 miles | 493.1 engine hours (OLM @ 24%) (3-28-21 to 9-22-21)
In: Mobil Delvac 1300 super 15w40, AcDelco PF2232
The truck has 72,099 miles and 5,441.6 engine hours.
I also drained and refilled the transmission along with changing the internal and external transmission filters. I changed the transfer case fluid with ~2 quarts of Pennzoil Platinum Dex VI/Mercon LV.
2005 Chevy Trailblazer (4.2) 67,563 miles
Out: M1 Annual Protection 5w30, XG9837
OCI: 4,209 miles (3-5-20 to 9-23-21)
In: 7 quarts of M1 Annual Protection 5w30, XG9837
2003 Chevrolet Cavalier
2.2 Ecotec 4 cylinder
Out: unknown, unknown cartridge filter
In: Napa synthetic blend 5w30, Napa Proselect 27082 filter
2005 Chevrolet Impala
3.4 V6
Out: unknown, Pronto PO111 filter
In: Napa synthetic blend 5w30, Napa Proselect 21040 filter
1999 Oldsmobile Cutlass Supreme
3.1 V6
Out: unknown, AcDelco PF47E filter
