Post your latest oil change
O.C. : '13 Honda Fit with 5 speed auto
Out : MOBIL1 Annual Protection 0w-20 ( S.N. , GF-5 ) w/ FRAM Ultra XG7317 . Time in use / miles : 10/1/20 > 9/10/21 , 9,135 miles
In : SHELL Rotella Gas Truck 0w-20 ( S.N.+, GF-5 ) w/ NAPA Platinum PFL 47356
FRAM started to leak from metal on top of filter to bottom a few days before , found oil on oil pan and bottom car . Good thing I check for any issues every few days .
2017 Toyota Camry 27,288 miles 5,000
Out: 5 quarts of Mobil 1 0W-20
Off: Mobil 1 cartridge filter
In: 5 quarts of Castrol Edge 0W-20
On: Mobil 1 cartridge filter
Had about 2,000 on the oil but it has been awhile since it was changed I think close to a year and so my dad said go ahead and do it. We were going to put Mobil 1 back in it but all of the Walmart stores were completely sold out of just about everything so the Castrol was our only option besides Royal Purple. But it’s a great oil I like Castrol so I’m sure it will be fine we were just keeping the same thing going in it because it was doing fine. I think the oil capacity is actually 4.8 quarts but I have a hard time stopping on time lol.
2014 Toyota RAV4 2.5L l4, 135,165 miles on odometer.
Out/off: 4.6qts Citgo 5W-20 synblend SN, Genuine Toyota Filter, OCI: about 5000 miles.
In/on: 4.6qts Valvoline White Bottle/Daily Protection (synthetic blend) 5W-20 SP, Denso 150-3021 oil filter.
Also replaced the engine air filter & cabin air filter, and did a brake job on all four corners (all new pads and all new rotors & hardware). Rotated tires.
2010 F-150 5.4L 3V V8, 58,979 miles on odometer.
Out/off: 5qts Rotella Gas Truck 5W-20 Synthetic and 2qts Resolute 5W-20 conventional. OCI: 4,479 miles (short trips, idling, on/off often).
In/on: 5qts Citgo Synthetic Blend 5W-20 & 2qts of a mixture of 5W-20 and 5W-30, FRAM PH2 oil filter.
Also replaced the blower motor and blower motor resistor.
1992 K1500 5.7L V8, 75kish miles on odometer.
Out/off: A conventional/synblend 5W-30 (don't remember), Wix 51036 oil filter. OCI: about 1700mi, annual oil change.
In/on: 5qts Resolute Synthetic Blend 5W-30, and a FRAM PH3980.
2015 Ford F150 3.5 Ecoboost
OCI: 4 months ~3100 miles
Out: Kirkland synthetic 5w-30, FL500S
In: Valvoline AFS 5w-30, FL500S
2008 Ford Crown Vic PI 4.6V8
OCI: 5 months ~3000 miles
Out: Valvoline Maxlife Plus 5w-30 Fram FPS2
In: Same oil, Wix XP filter
2019 Ford F150 2.7 Ecoboost
OCI: 4 months ~3500 miles
Out: Valvoline AFS 5w-30, FL2062A
In: Mobil 1 AFE 0w-30, FL2062A
Did my buddies 2016 civic 1.5T earlier.
Out: Pennzoil Black Label 0W20 and PH7317
In: Valvoline 0W20 and PH7317
I think he put about 6-7k on the oil since I did it last. Not sure, he mainly goes by the oil life and changes it around 30%.
Also did a rotation and found a bubble in his sidewall so I bought 2 Goodyear tires at Walmart on clearance and threw those on for him too. I hope they don't give him any trouble cuz they were the ones we always had issues with when I worked there.
He was salty cuz Walmart was out of everything Pennzoil so he settled for Valvoline.
And did another buddies 2013 Mazda speed3 2.3 turbo
Out: unknown oil and pro tec filter
In: Thrive synthetic 5W30 and OEM filter
The oil came out so thick and dark I swear it was Diesel oil. Told him to stick to 3k oil changes because he beats on it and the timing chains are an issue with the turbo motors. Hopefully it gives him many trouble free miles.
2002 Xterra 285,000km 3.3L Supercharged
Out: M1 5w30 and M1 Filter - No noticeable consumption on the dipstick in 7000km
In: Shell Rotella Gas Truck and a fram XG7317
First time I noticed the RGT in stores near me so I decided to give it a try.
2018 Acura RDX Technology
28,004 miles
OCI: 8 months, 4132 miles, my first OC since purchase
Out: Florida Cadillac dealer's ACDelco synthetic 5w-30, Honda filter
In: Pennzoil Ultimate Platinum 5w-20, Carquest Blue filter
In my NC and FL climates, I don't need no stinking 0w-20.
Compared to other Hondas and Acuras I've owned since 1990, removing this oil filter was a pain in the butt, with oil leaking along a cross member. Next time I'll use a plastic bag. Never saw this before on Honda or Acura vehicles. And the oil fill cap is tough to reach also. Poor design.
Just did the 20K oil change on the 2018 Camry Hybrid SE. Oil had about 5,000 miles on it.
On this particular vehicle, I did it originally (early) at like 1,500 miles on the ODO, but then did the dealer freebies at 7,500 and 15,000.
I never have such a hard time removing an oil filter in my life.... I have two tools to help remove filters, including the Toyota 'cap' end tool. Well, neither worked and completely stripped the 'grip'/grooves in the end of the filter. After about 30 minutes of fighting it, hammered a screwdriver through the side to give me more leverage. It just started to give, thankfully. Once I got it moved about 5-10 degrees, had to hammer another hole through and with the help of the screwdriver and filter removal tool, was able to get it going.
Was messy and frustrating, to say the least. A gorilla must have installed the previous filter. I have had some fighters in the past, but never to the point of having to hammer a screwdriver through it!
Filled up with M1 0W16 and a FRAM Ultra Synthetic XG4967 filter. At least next time should go far smoother!
I just did my first oil change on my 2021 Nissan Frontier 3.8 v6 4x4 with 5020 miles on the factory fill oil, which I have sent in to Blackstone and am waiting on a report. I refilled with 5 quarts Supertech 0/20 and a Mahle, made in Japan, factory oil filter. The filter was under $11 and the oil under $18.
