2015 Volvo S60, 29,927 miles on car, 10,056 on the oil.
Out: Mobil 1 EP 5w30; Ecoguard S5581
In: Mobil 1 EP 5w30; Ecoguard S5581
Does the mityvac get all of the oil out?Another 15 minute topside change thanks to the mityvac.
Maintenance Minder A service so no filter change - Using Napa Platinum with a filtermag.
Fill up with Idemitsu 0-w20 Zepro ecomedalist.
Im good for about another 10K.
As much as pulling the drain plug. Sometimes better, many drain plugs dont actually drain from the bottom of the pan.Does the mityvac get all of the oil out?
I have used the MityVac on 2 Acura TSX K24, 2013 Civic LX, 2015 Nissan Altima 4 banger all with excellent results.Does the mityvac get all of the oil out?
Worked well for the FIT A.T.F. removal. Used large hose .I have used the MityVac on 2 Acura TSX K24, 2013 Civic LX, 2015 Nissan Altima 4 banger all with excellent results.
It comes with 2 size plastic tubes to stuff into the dip stick tube. I use the dip stick to estimate how far the MityVac tube should go.
You might have to fish the tube around a little, but you will get there. I only use the smaller tube now.
I tried sucking out the ATF outta the 2013 Civic; I was not very successful. But it's good to clean the magnetized drain plug anyways.
That's great! The 300 is a great car, too! I rented a couple and was always very impressed with them.
