Post your latest oil change
2008 Dodge Ram 3500 diesel.
258820 miles total, 4566 hours
9100 miles on oil, 197 hours
Out: Kendall Super D-XA 15w40
In: same
No filter change
Plugged EGR valve back in. See if oil oxidation comes back.
1993 Dodge Ram W150
5.2 Magnum V8
Out: Castrol GTX 10w40, Motorcraft FL1A filter
In: Chevron Delo 400 15w40, AcDelco PF2 filter
1978 Chevrolet Corvette
383 small block stroker V8
Out: Amsoil Dominator 15w50, Wix 51069R racing filter
In: Amsoil Dominator 15w50, Wix 51069R racing filter
1994 Ford F350
7.5 V8
Out: Amsoil Signature Series 10w30, Motorcraft FL1A filter
In: Napa Synthetic HM 10w30, Napa Gold 1515 filter
Honda CRV 1.5Turbo 2018 - Out Honda 0W20, In Eneos,Sustina 5W30
Honda CRV 2.4 2WD 2014 - Out Honda 0W20, In Eneos Sustina 5W30
Acura TSX 2005 - Out Mobil 1, In Liqui Moly AA 5W30.
2005 Toyota Tundra
4.7 V8
Out: Supertech Conventional 5w30, Supertech ST3614 filter
In: Quaker State Advanced Durability 5w30, Supertech ST3614 filter
2007 Acura TSX, K24, 146K, 5K OCI, 10% maintenance minder
Out: 4+ quarts M1 High Mileage 5w20; Fram UG 7317 (2 OCI)
In: 5 quarts Halvoline Box Syn 5w30 (thanks Critic); Fram UG 7317
I would say it used 1/2 quart. Mostly around town.
Replaced air filter as well. Used Denso; good price on Amazon.
2011 Avalon
Out: Supertech 5w30 and Super Tech Filter
In: 4qts Quaker state Hi Mileage, 3qts Resolute
Interval - 5900 miles
2019 Freightliner M2-106 B6.7 Cummins. Company owned vehicle. Our mechanics are refusing to service the brand new trucks. Driver wants me to do oil change since I work on cars.
Out: Factory Fill and Filter after 25,000mi.
In: Costco 15W40 and Fleetguard oil filter.
On 10-21-20:
2005 Ford Mustang GT - 141,260 miles
In: Valvoline MaxLife Synthetic 5W-20 + 1 quart of Napa Synthetic 5w30, Purolator One PL24651
Out: Mobil 1 High Mileage 5W-20 (I can't remember for sure), Purolator PureONE PL24651 (old yellow can)
Approx 1 year on OCI with roughly 4k on it.
2008 TrailBlazer 4.2L
OCI:Around 4000mi
Out: Delo 400 XSP 5w40
In: 5qt Rotella Gas Truck 5W30 + ~1.5qt Delo 400LE 5w40 since it was already open.
Kept the Fram Ultra XG9837 in place, didn't really need to change the oil but I was bored and have plenty of oil plus winter is coming up figured a little bit thinner oil might be better if we have a bad winter, Not sure if I'll go 5000mi on this change or 7500mi, I think the OLM is programmed for like 7500-10000mi or something because the sump is so large on these engines.
1993 Oldsmobile Cutlass Ciera
3.3 V6
Out: Pennzoil Conventional 10w30, AcDelco PF47E filter
In: Pureguard synthetic blend 10w30, AcDelco PF47E filter
Changed oil in my son's 2008 Ford Ranger 2.3 today. OCI was 13K with no oil consumption.
Out: Mobil 1 5w20 Extended Protection High Mileage.
In: Mobil 1 5w20 Extended Protection High Mileage.
Oil Filter: MC FL 910S in and out
2011 Nissan Sentra 2.0 S
Out: Super Tech Full Syth SN+ 5w20
In: A bit over 4qts Super Tech High Mileage Full Synthetic SP 5w30 (5qt jug just a tad under 1qt mark remaining).
Checked dipstick when finished, oil level just above H; after about a 10 mi drive (mixed city/65mph+ highway), and 5 min cool down, oil level still just above H. So, I hope it's not overfilled.
Off: Denso 150-2002
On: Fram TG6607
181 days and ~2,234 mi. on oil and filter.
Denso Air filter from previous OC on 05/02/20 was checked, but not replaced.
1984 Ford F150
300 inline six
Out: Castrol GTX Magnatec 10w30, Fram Extra Guard PH8A filter
In: Supertech conventional 10w30, Supertech ST8A filter
1999 Pontiac Trans Am
5.7 LS1 V8
Out: Amsoil Signature Series 5w30, AcDelco PF46E filter
In: Amsoil Signature Series 5w30, AcDelco PF46E filter
2008 Ford F150
4.2 V6
Out: Castrol GTX 5w20, Fram Extra Guard PH3600 filter
In: Valvoline Daily Protection 5w20, Motorcraft FL400S filter
2002 Ford Ranger 3.0 Vulcan, 260k miles
Out: RGT 5w30, Bosch 3422 10,277 miles
In: Harvest King 10w30 syn, Bosch 3422
I had been planning to use Mobil 1 Extended Performance High Mileage 5w30 this time and run it for 20k but I decided to use up some of my old SN Plus stock instead. Have several 5 gallon buckets to use up still.
I was also planning to take a sample for a used oil analysis but I dumped the oil at 1 AM and forgot to save some 🙄
I will C&P the filter, though
