Post your latest oil change
Originally Posted by kstanf150
2018 Ford F-250
6.2L Gas motor
Out: RGT 5w30 and Fram XG filter
In: Quaker State High Mileage 10W-40 SynBlend / Mobil 1 filter
HM on a 2018? Whats the mileage?
2018 Ford F-250
6.2L Gas motor
Doing a little in house experiment
Engine only has 32K miles but it's always had a valve train tick
Ford says it's normal
I've tried a couple of 5w30 SN plus rated oils and engine sounds the same
Quaker State High Mileage is a robust SN rated oil so gona give it a try for fun and see what happens
1993 Volvo 240 Sedan
Out: Rotella T5 10W30
In: Rotella Gas Truck 5W30
Mann W917 filter
1993 Volvo 240 Wagon
Out: Delo xle 400 10W30
In: Rotella T5 10W30
Fram XG8A filter (remote mount)
1988 Mitsubishi Galant
After ~6000mls:
Out: Q8 F1 10W-50
In: Meguin Megol SL 5W-40
Filter: In & Out: Hengst H13W01
Winter's coming in Germany...
2014 Ford F-150 50,750 miles.
Out: Mobil 1 0W-20.
In: Castrol Magnetic 0W-20. I kept the same oil filter on the vehicle because I change yearly and it only had approximately 3,000 miles on it. I mainly use this
vehicle for towing my boat back and forth on longer trips such as 350 miles or less round trip. The oil was fairly clean looking and probably overkill but I will keep this truck for quite a while. It has the off road metal plate under the engine and when I change the filter it drips for literally a couple days and I avoided that by not changing the filter this time.
Daughter's 2019 Kia Sportage 2.4L AWD
25,425 miles
OCI: 4425 miles
Out: Valvoline 5w20 conventional and Valvoline filter
In: Havoline ProDS synthetic 5w-20, Wix 51334XP filter
2010 Kia Soul 2U, 2L I-4, 149k on car.
Out:
Castrol GTX HM 5w30, STP blue bottle and Fram TG9688 filter.
Approx. 6400 miles on oil, 1.5 quarts top off.
In:
Castrol Edge (black bottle) 5w30 and Fram TG9688 filter.
2010 Ford crown Victoria police 110K miles
Out: Mobil Super 5000 Champ COS3614
In: Rotella gas truck Full Synthetic 5W20
Kept the Champion COS3614 since its same as a Mobil 1 filter with silcone ADBV good for AT LEAST 2 OCi's
Dave
Originally Posted by harry j
1993 Civic 562,042 miles. 6,421 this run.
Amsoil AZO 0w30 and an amsoil EA15K20 filter.
My guess is you won't see many of these Honda's with that kind of miles.
Have mercy.
Well done!
Originally Posted by mpack88
Never knew the police interceptor's use that old thread pitch. You could use a fl1a if there's enough room or a fl400s.
Ya don't know reason why the police pkg got its own filter towards end of panther production ?? It was a PH2/XG2/FL820S across the board up to 2008. Then 2009-2011 the police interceptors got it's own smaller filters FL910S and the civilian cars stayed same FL-820/XX2 series ??
Any who, I'm gonna be running XG3614 from now on with my police vics
Dave
Well I just found out my worker guy/mechanic changed my request of oil change on the 2010 Police vic without me knowing BLAH lol
He used
Mix 3 qts of Mobil super syn 5W20 and 3qts Havoline Full Synthetic 5W20. This was from my stash of Pep boys summer clearance wave.
Paid like $1 a qt for that stuff lol
And a fresh new XG3614 filter........FREE thanks to Amazon CS LOL
Dave
Originally Posted by ka9mnx
Ford back spec'd just about all their engines to 5w20 in the early 2000's.
Wow I didn't know this, it's so ate up ford always just decides it's all of the sudden ok to use a new fluid.. same thing happened with mercon and do not put mercon v in your trans, then all the sudden they changed the spec to mercon v.
He used
Dave
If you ever want to see.one of your filters cut open, let me know
