Originally Posted by N Heat
Originally Posted by kstanf150
2018 Ford F-250
6.2L Gas motor
Out: RGT 5w30 and Fram XG filter
In: Quaker State High Mileage 10W-40 SynBlend / Mobil 1 filter
HM on a 2018? Whats the mileage?
Doing a little in house experiment
Engine only has 32K miles but it's always had a valve train tick
Ford says it's normal
I've tried a couple of 5w30 SN plus rated oils and engine sounds the same
Quaker State High Mileage is a robust SN rated oil so gona give it a try for fun and see what happens
Out: Mobil 1 0W-20.
In: Castrol Magnetic 0W-20. I kept the same oil filter on the vehicle because I change yearly and it only had approximately 3,000 miles on it. I mainly use this
vehicle for towing my boat back and forth on longer trips such as 350 miles or less round trip. The oil was fairly clean looking and probably overkill but I will keep this truck for quite a while. It has the off road metal plate under the engine and when I change the filter it drips for literally a couple days and I avoided that by not changing the filter this time.
Originally Posted by mpack88
Never knew the police interceptor's use that old thread pitch. You could use a fl1a if there's enough room or a fl400s.
Ya don't know reason why the police pkg got its own filter towards end of panther production ?? It was a PH2/XG2/FL820S across the board up to 2008. Then 2009-2011 the police interceptors got it's own smaller filters FL910S and the civilian cars stayed same FL-820/XX2 series ??
Any who, I'm gonna be running XG3614 from now on with my police vics
Originally Posted by ka9mnx
Ford back spec'd just about all their engines to 5w20 in the early 2000's.
Wow I didn't know this, it's so ate up ford always just decides it's all of the sudden ok to use a new fluid.. same thing happened with mercon and do not put mercon v in your trans, then all the sudden they changed the spec to mercon v.
Originally Posted by GMguy84
Well I just found out my worker guy/mechanic changed my request of oil change on the 2010 Police vic without me knowing BLAH lol
He used
Mix 3 qts of Mobil super syn 5W20 and 3qts Havoline Full Synthetic 5W20. This was from my stash of Pep boys summer clearance wave.
Paid like $1 a qt for that stuff lol
And a fresh new XG3614 filter........FREE thanks to Amazon CS LOL
Dave
If you ever want to see.one of your filters cut open, let me know
