Post your latest oil change
2012 Hyundai Sonata 2.4
89k miles
Castrol Edge GDI Formula 10W30, OEM filter
Drain plug 30 ft lbs
2005 Cadillac STS 3.6
Quaker State Advanced Durability 5W30, Fram PH8765
Drain plug 18 ft lbs
Wife's grandmother's 2000 Honda Accord with 2.3 litre engine
Out: Valvoline Conventional 5W30 and Honda filter
In: Valvoline Advanced Full Synthetic 5W30 and Motomaster OE Plus 9688
The car has 55,000 kms on the odometer and she drove 377kms since I last serviced the car in October 2018.
2014 Jeep Grand Cherokee 78k
Out: Magnetic 5W20 and Fram Ultra oil filter ~8.2k
In: Napa Full Synthetic 5W20 and Napa Gold oil filter
Out : NAPA 5w20 SB with Federated PG241F filter.
In : Havoline 5w20 conv in the 6 quart box, and a Fram PH3614.
2004 F150 5.4 V8
176,773 miles on truck, 4088 miles/6 months on oil and filter.
Out:
Valvoline HM syn 0w-20 (5 qts) and Valvoline SAE 30 conventional (2 qts) and 1 qt top off oil (used oil (0w-20) with 5000 miles from my Scion).
Fram TG2 filter.
In:
Castrol Magnatec 10w30 syn blend.
Supertech ST2 filter.
[Linked Image]
[Linked Image]
2011 Ford Fusion SEL 2.5
Out:
Mobil 1 Advanced Fuel Economy 0w20
Motorcraft filter
In
Castrol Edge Extended Performance 0w20
Fram TG
Planning a 10,000 mile run.
2014 Honda CR-V 2.4L
Out: Mobil 1 Advanced Fuel Economy 0w20 - Mobil 1-110A Filter
In: Mobil 1 Advanced Fuel Economy 0w20 - Mobil 1-110A Filter
58,600 Miles
Churning through the Walmart/Mobil 1 Spring rebate oil.
1999 Camry V6, 220K miles; belongs to our house cleaner lady.
Her tires were bald; Wheel Works fixed that.
The plastic oil cap was broke to heck; replaced it and oil drain plug. Hate worn plug threads...
Out: Quickie lube conventional; "Mighty" filter looked like a Wix maybe?
In: SuperTech High Mileage 5w30 and Super Tech filter.
Spilled a bunch of oil out the side of the funnel; those V6 Toyota valve covers...
Cat litter to the rescue!
All good. Her kids will be safe now; I'm happy.
2009 Accord V6. 130,500 miles
Out: Super Tech 0w20 High Mileage, Fram TG7317
In: Super Tech 0w20 High Mileage, Bosch 3323
Also dumped the ATF and refilled about 3.2 qts of Honda ATF-DW.
Runs like a top, except for a bad front motor mount and getting sloppy lower ball joints (on my to-do list).
2002 Xterra Supercharged
Out: 5w30 Motomaster F1 Synthetic and Motomaster MPH7317
In: 10w30 Quaker State Synthetic and QS14612
Got the oil for free so may as well use it.
Also changed the transmission fluid today. No idea what came out but it was decently clean, did one drain and fill with Maxlife. Will do the next 2 with Amsoil that I have stocked up.
2015 Infiniti G37S 6MT 16k miles
Out: Mobil 1 FS 5w30 and a Nissan 65F0E filter
In: RedLine 5w30 and a Nissan 9E01A filter
M1 only had 1000 miles on it, but I've got a long road trip coming up and the VQ motor is a meat grinder on oil. Hopefully the ester stock will help with valvetrain noise
Good on you sir
