Post your latest oil change
a pre post oil change
car: 2007 nissan altima with the 3.5, 84000 miles. oil is 3 years old with 4000 miles. ran it 1.5 miles after sitting 3 years, it stops and goes. going another 2 miles for oil change at nissan tomorrow.
I can't believe it started after a 3 year hibernation with just a new battery. Of course, new air filter and new tires on. I just dont want to get under a car on ramps anymore, and the nissan pushed the old ramps I had anyway due to lower front end. So dealer it is for bulk junk and 29 bucks. Whatever, its only staying in until spring. I will get better ramps, and change to mobil 1 after the "winter flush" from not running. Should be 1 to 2k oci to spring.
2014 Silverado
Current mileage 71952
In:
8qt Valvoline Full Syn w/ Maxlife 0w-20
Fram TG10575
Out:
Castrol Magnatec 5w20
Fram TG10575
7774.7mi on oil, olm @ 1%
Took a sample for analysis
Latest:
2002 Toyota Sienna LE
Pennzoil Ultra Platinum 5w-30
Mobil 1 Extended Performance oil filter
Next:
2013 Jeep Grand Cherokee 5.7
Royal Purple API SN 5w-20
STP XL oil filter
Before Sienna:
2004 Corvette LS1
Mobil 1 High Mileage 5w-30
STP XL oil filter
Before Corvette:
2000 Toyota Tacoma 3.4
Royal Purple HMX 5w-30
STP XL oil filter
Will switch Corvette and Sienna to HMX. I'd like HPS in the Corvette but its oil pan gasket leaks without high mileage oil.
2013 F150 5.0
53,500 miles.
Out: MC blend 5w20
6k miles. IOLM unknown.
FL500s
In: Chevron Supreme 5w20
FL500s
Installed Fumoto F107n. The n is not needed unless drawing samples. I may cut it off.
Originally Posted by mobilaltima
2005 Dodge Ram 2500 5.9 Cummins
421,287 miles
Mobil Delvac 15W40, Fleetguard Stratapore LF16035
You might just get your money's worth at this pace … !
That's a solid oil made from the GII+ posted here recently …
2017 Tahoe 4WD at 20k / 7k OCI to 7% OLM
Out/off: Mobil 1 EP 0W20 and PF63E
In/on: Mobil 1 EP 0W20 and RP 20-500
2010 Ford Fusion 2.5L - 267,494 miles - 7,469 miles on oil.
Oil out: 3qt Havoline Supreme Conventional 5w20 + 2qt Havoline High Mileage 5w20 + 0.4qt Valvoline NextGen 5w30
Filter off: Supertech ST3600
Oil in: 2.4 qt Havoline Supreme Conventional 5w20 + 3 qt Havoline High Mileage 5w20
Filter on: Federated LF483F
2000 328Ci; 122306 miles
Out: Pennzoil Platinum Euro 0W-40; Mahle OX 154/1 D filter; 6081 miles; no make-up oil since last change at 116225 miles
In: 5 qts. Pennzoil Platinum Euro L 5W-30 + ~1.7 quarts Pennzoil Platinum Euro 0W-40; Mahle OX 154/1 D filter
2012 Hyundai Santa Fe. 138K
Out: Havoline pro DS 5W-20 Full Syn. Went 8K. Longest I have ever gone. No issues to report.
In: Same, except 5W-30 and a WIX filter.
Very good choice. My son has 85K on his 2016 Tahoe using M1 0-20EP and is doing 12-15K OCIs. All is well.
A bit overkill for 7k (warranty) but it was just $5/quart ... The filter was the first I found with 20+ psi PRV ... and was getting over "e-core paranoia" ... won't spend that much again after finding a Baldwin with higher psi (have some PF63's too) ...
Good read on these engines
http://gmauthority.com/blog/gm/gm-engines/l83/
2002 Toyota 4Runner, 192,500 miles
Out: SuperTech Fully Syn. HM 5-30, Run 4500 miles, no makeup oil added
In: Havoline Semi-Syn. HM 5-30, I left on the Fram TG filter from the last run.
I plan on running this 4500 miles, which seems to be a good distance with the number of short
trips my daughter takes while away at school.
2001 Suburban 1500
260,000 miles Original 5.3/4L60E drivetrain
Out: Chevron Delo 400XLE 10W30
In: Mobil 5W30 Annual protection
Kept the XG on for one more OCI
Dave
2007 mazda 3 2.0 195k
Out: Napa 5w30 synthetic 10k on oil
In: Penzoil Platinum High Mileage 5w30
Kept on the oversized XG3600 for 2nd OCI
2016 Yukon XL 5.3 19k
Out: Resolute 0w20 synthetic 7500 on oil
In: mix of Resolute and Napa synthetics 0w20
Wix WL10256XP (the correct filter with 22psi relief valve)
