Post your latest oil change
66 rachero 289
Out: 5 qts ecopower 10w30, 1 qt gasoline
In: 5 qts syntec 20w50.
Carb was running super rich and flooding the engine. Got it rebuilt and working good now!
Same oil pressure with the 20w50 as 10w30.
2004 expedition 5.4
Out: mobil clean 5000 5w20 with kreen (800 miles on it) and parts master filter
In: mobil 1 ep 0w20 with fl820s motorcraft filter
Also changed front differential to mobil syn 75w90 and rear to 75w140. Transfer case to havoline mercon v
2014 Jeep Wrangler Pentastar
Out-whatever the dealer put in 3000 miles ago
In- PP (natural gas stuff) 5w-20 with Mopar filter
'01 Focus, about 101K car, about 3.2K and six months oil.
Out: Synpower 10W-30, AAP Total Grip filter
In: Meijer full syn 5W-20, Motorcraft filter
Wanted to get the 10W-30 out before real cold arrived, although the 10W-30 Synpower was okay on the three 10F mornings it saw this fall. No trouble starting and no unusual noises.
2002 Hyundai Elantra GLS - 10w-30 Amsoil OE and Amsoil filter
2009 Lexus LS430 - PP Ultra 5w-30 and OEM filter
2004 Honda Civic SI - 5w-30 Amsoil SS and A01 filter
2009 Ford Fusion 3.0 Out Quaker State 5w20 conventional and Fram oil filter.In MotoMaster Supreme 5w20 conventional and Fram oil filter..Fusion had 5,437miles before oil change
Another pretty winter day so I squeezed in a couple of oil changes.
2011 Toyota Land Cruiser - 8 qts of PU 5W-20 and an OEM Toyota filter
2010 Toyota Camry - 5 qts of Peak 5W-20 dino and a Microgard filter (old style FRAM Extra Guard clone)
Should take care of everything until spring.
Originally Posted By: splinter
'11 GMC 5.3L Sierra
M1 0W-40 + Fram Ultra XG10575
6 months/~6100 miles/8% OLM remaining
So do you notice any differences running this oil vs a 5w-30.
'11 GMC 5.3L Sierra
Ha I was needlessly alarmed when I drove the AFM truck home new at its 'low' pressure (compared to other LSs and SBCs I've owned/driven).
Produced ~25-psi at hot 550-rpm idle but only ~35 during highway cruise.
Swapped out the FF asap with 0W-40 and picked up 5 psi on the freeway (idle remained essentially the same).
It's never had any other viscosity in it since then.
2007 FJ cruiser. 76k miles.
(new) Pennzoil Platinum 5W30
PureOne filter
Thing loves this oil. I change 5k-7k depending on what I've been doing, but this time I'm on 8500 miles. Seems good and clean still, so why not...
Happy New Year BITOG guys!
2013 Subaru Impreza
Out: Mobil Super 0w-20 and Fram Extended Guard XG-7317
In: Castrol Syntec Edge 0w-20 and another XG-7317
2011 toyota sienna
out:
i forgot and microguard filter
in:
6~ quarts vavoline nextgen 5w30
1/4th quart 5w20 mobil 5000
1/4th quart 5w40 rotella t6
purolator classic cartridge filter
2002 Ford F-350 7.3L Power Stroke
94,000 kms.
Out: Rotella T 15W40 Motorcraft Filter
In: Rotella T 15W40 Mann Filter
1991 Toyota Corolla Wagon
249,700 kms.
Out: PO Mystery Oil Bosch Filter
In: Pennzoil HM 10W30 Mann Filter
