Post your latest oil change
2009 Mercury Sable 76,400mi
5,630 mi/8mo 1 day on oil (2,400mi in last week on vacation)
Out: 5.5qts Meijer Full Synthetic (warren unilube)5w20, FL-400s, Purolator Air Filter that came with the car, Date coded 09/12/12
In: .5Qts PP(old)5w30 + 5qts Pennzoil Platinum PurePlus 5w20, Wix 51516, New Wix Air Filter.
also replaced Drain Plug With a Fumoto Valve (F-107N)
'06 Montego
mileage:139833
5qts Super S Semi-Syn 5w30
1qt Formula Shell 5w20
Purolator Classic OF
NOTE: OLM was at 2% left. Last oil change was 5 months and 1 day ago, 5/10/14. Mileage nearly exactly 5K since.
'12 Acura TL 6MT
mileage: 35,010
out: mixture of Napa Full Synthetic 5w20 and PU
in: 4 and a half qts of Valvoline 5w20 Full Synthetic
oil filter Fram Ultra
MM was at 30%. Now with a new ultra filter, I plan to go a little bit longer with next OCI, maybe down to 10% on MM.
2012 Honda Civic, 1.8L, 53,800 miles
Out: Mix of 3 quarts Mobil 1 Advanced Fuel Economy 0w-20 and 1 quart Mobil 1 Extended Performance 0w20, Honda Filter
In: Mobil 1 Extended Performance 0w20, Honda filter
The Maintenance Minder showed 40% remaining and it had been 7300 miles since the last service.
1997 Toyota Camry 4cyl, 325,450 miles.
Out: Mobil 1 High Mileage 5w30 and Mobil 1 filter.
In: Same
5k on previous
1995 Toyota Camry 4cyl, 172,500
Out: Pennzoil Platinum 5w30 and Bosch D+
In: Mobil 1 High Mileage 5w30 and Mobil 1 filter.
2011 Toyota Camry 4cyl, 33500
out, Pennzoil 5w30 synblend, Napa Pro Select filter from used car dealer prep.
Previous OCI unknown.
In,TGMO 0w20
, Toyota oil filter, plus put crush washer on drain plug, none there when I removed the plug.
2000 Ford Explorer 4.0L OHV
OUT: Pennzoil Ultra 10w30 & Purolator PL30001
IN: Pennzoil Ultra 5w30 & Purolator PL30001
With the clock at 197863, this will have been the last oil change before the 200000 milestone.
2011 Ford F150 with 3.5 litre Ecoboost
In: Mobil 1 Advanced Fuel Economy 0W30 and Fram Ultra 10575
Out: Co-op Sonic Gold SL 0W30 and Fram Ultra 10575
2007 Honda Accord Hybrid, 101,000 KM
Out: 5w30 Pennzoil Platinum Pure Plus, Wix XP filter
In: 5w30 Quaker State Ultimate Durability, Bosch Premium filter
2007 Acura RDX, 133,000 KM
Out: 5w30 Pennzoil Platinum, Bosch Premium filter
In: 5w30 Pennzoil Platinum, Wix XP filter
2004 Acura TSX, 145,000 KM
Out: 5w30 MotoMaster F1 Synthetic, Bosch Premium filter
In: 5w30 MotoMaster F1 Synthetic, WIX XP filter
NEXT WEEK ITS GOING TO BE
2007 Acura TL Type S, 109,500 KM
Out: 5w30 Pennzoil Platinum Pure Plus, Bosch Premium filter
In: 5w30 Pennzoil Platinum Pure Plus, Bosch Premium filter
2006 Chevrolet Impala 150k miles
5k mile OCI
Out: Mobil 1 5w30 - Bosch oil filter
In: Pennzoil Platinum 5w30 - Fram Ultra filter
2003 Toyota Highlander 3.0L
Out: Castrol GTX 5w-20 and Defense filter (oversize)
In: Same as above
OCI: Approximately 6 months and about 4k Kms.
2006 Nissan Frontier 4.0 V-6, 140,000 mi
AMSOIL Signature Series 5w30 (ASL); Ea15k-13; EaA-104
OCI 10,000 - 12,000 miles (6-months of driving, spring and fall)
Have followed this since the vehicle was new. Zero oil consumption between servicings
2013 GMC 1500 5.3
5W40 Pet-Can Duron CJ-4/SM
AC DELCO
2011 GMC 2500 Duramax
SAE 30 Duron
AC DELCO
GE AC44 MTU
SAE 40 (Zink-free)
210 gallons
2013 Matrix (2)
15W40 Mobil 1300
Bosch
2006 Chev 3500 Duramax
15W40 Rotella-T
AC Delco
Both Diesels and Matrix will use
5W40 for winter
2010 Mercedes GLK350 3.5L V6
5 quarts Mobil 1 0W40 ....and .... 4 quarts of Mobil 1 0W20
Should be the perfect mix for our cold winters in high mountain Colorado.
I will run the oil 10k miles.
2009 f150
Out: 7 qts ecopower sm 5w20 4800k miles, purolator classic
In: 7qts orielly syn 5w20, napa gold (truck just rolled over 100k miles)
