Post your latest oil change
2009 Buick Enclave CXL
43420 miles OLM 47%
Out: Pennzoil Ultra 5W30 and M1 M1-212 Filter
In: Pennzoil Platinum Ultra 5W30 and AC Delco Pf-63
I have been using M1, NAPA Gold, or Royal Purple filters but for whatever reason decided to go with AC Delco this time. I do an oil and filter change when the OLM reaches around 50% to 45% (3750 to 4200 miles) because of known timing chain issues with the 2009 3.6 engines plus the beating the 3.6 DI does to any oil. Hopefully the OEM AC filter will be as good as the others used for for my typical OCI period.
2009 Honda Accord EX 181,285 miles
Out: Valvoline MaxLife HM Syn Blend 5W-20 & Purolator Pure One Filter (PL14610) 4595 miles
In: Pennzoil High Mileage 5W-20 & Bosch 3323 Premium Oil Filter
2003 Pontiac Vibe - 1ZZ-FE - 1.8 4cy - 182,544 miles
OCI - 4,997 miles
Out - Amsoil OE 5W30 syn and Motorcraft FL-400S
In - Shell Formula Dino 5W30 and Fram PH4967 with 250 ml of Liqui Moly MOS2
2005 Ford Focus ZX4 SE - 2.0 4cyl - 61,274 miles (Parents vehicle)
OCI - 7.5k-ish miles - 7 month period
Out - Midas bulk oil - weight/type unknown - Napa Select 21348 filter
In - 4.5 qts of Pennzoil Yellow Bottle -5W20 with Mahle Micro Star OC981 filter
2007 Toyota Sienna, 3.5 litre V6
Out: Mobil 1 0W30 AFE and Purolator Classic filter
In: Mobil 1 0W30 AFE and Toyota OEM filter
2005 Honda Civic
Out: VML 5W20 and Bosch D+ 3323
In: Castrol HM 5W20 and FRAM Ultra 7317
Filter is a PITA to change due to its location and mounting position. Planned FCI is 15k over 3 OCs.
2014 Jeep Wrangler Unlimited Sahara
12,147 total miles
This OCI = 5,070 miles
Out: Pennzoil Platinum 5w20 and Mopar 349 filter
In: Pennzoil Platinum Ultra 5w20 and Mopar 349 filter
Next OCI will be 4,000 - 5,000 miles.
1988 civic LX 1.5L 79,000 Miles
Just did the oil change using the Pennzoil Platinum 5w30 synthetic and Baldwin B161S filter.
Out was Amsoil 0E 5w30 with 4500 miles OCI with Bosch 3312 filter.
For the 1996 Toyota Avalon the winter blend is now in the car.
The old oil filter is still in the car with about 1/2 quart of "old: oil, most of which would be remnants of:
1 quart of Supertech 20W-50 SN, four quarts of Napa 10W-40 SL grade fleet oil I got on a sale a few years back, and 1 pint of Marvel Mystery Oil.
I added about 3000 miles ago a quart of PYB 40W.
The five new quarts consist of Mobil 15W/50 Extended Performance (1), Mobil 5W/20 Extended Performance (1), a quart of 5W-30 Synthetic from O'Reilly, a quart of 10W-30 Valvoline, and one quart of 5W-30 Napa Synthetic.
The filter is a Bosch Distance+.
The oil and the filter will all be changed around 214,000 miles.
1989 Chevy Suburban - 5.7L - 350CI - V8 Automatic over 250k miles on unit (parents work vehicle)
OCI - Unknown - Possible 16 months time span.
Out - Midas Bulk oil- Weight and Type unknown - with a Napa ProSelect 21060
In - 5 qts of Shell Rotella T5 10W30 with a Purolator Classic L34631
