Post your latest oil change
10 fusion 3.0 47k,
out 9.5k on valvoline synpower 5w-20 w/ motorcraft filter
in Mobil 1 fully synthetic 5w-20 w/ motorcraft filter
*[5qt Mobil 1 + 1qt of left over valvoline from last change]
2009 f150 in sig.
Out: 7 qts ecopower sm 5w20, napa silver filter
In: 5 qt ecopower an 5w20 and 2 qts sl castrol syntec 5w30, purolator classic
1996 Cherokee XJ
Out: Gulfpride AFE 5w30 PGO-195
In: Peak 10w40 SA
*Almost killed the 6 5.28 quart jugs of Peak 10w40 that I bought last year on clearance at AZ for $3 per jug. 4.5 Quarts left.
1996 Cherokee XJ
In: Peak 10w40 S8A
Busy weekend so far for me, two vehicles needed a change.
2008 VW Jetta SE 2.5
Out - Rotella T6 5w40 (5050mi) - Napa ProSelect 27187
In - Rotella T6 5w40 - OEM Mann Filer
2008 Chevy Equinox LT 3400
Out - Rotella T5 10w30 (~2100K trial run/cleaning) - Purolator PL1011
In - Rotella T5 10w30 - Fram XG3387A
02 Silverado 5.3L
Out: NAPA Syn 0W20, NAPA Gold filter drained at OLM warning.
In: Pennzoil Platinum 0w20, LM MoS2, and Mobil 1 filter trying for an extended OCI.
2001 Bonneville SSEi
Out: 10w30 conventional FS & Quaker State oil filter
5.4k miles, 4 months. OLM @ 5%
In: 10w30 conventional FS & Wix filter.
2012 Fusion 4-cyl 2.5
Out: 5w20 Motorcraft semi-syn (last dealer freebie) and Motorcraft filter. 7500 OCI/FCI
In: 5q NAPA 5w20 full synthetic, Wix filter
2006 Dodge Grand Caravan (3.3l)
out: Mobil Super 5000 5w20 and NAPA Gold filter (5000 mi)
in: NAPA 5w20 synthetic and Purolator Classic filter (my last one on hand)
1990 Mazda miata
Out...Mobil 1 0w-30, recycled oversize NAPA Platinum filter. 8k on oil, 15k on filter.
In......3.8 qt Mobil 1 0w-30, New oversize NAPA Platinum filter.
Planning 8k OCI.. might run filter two cycles again.
08 Silverado: Out Valvoline 5w30 conventional and Napa Pro Select filter. In: 5 qts Valvoline 5w30 conventional and 1 qt Napa Synthetic 5w30, Napa Pro Select.
I did the first change on my wife's BMW since we bought the car a few weeks ago, I went with Mobil 1 0w40. I wanted to change the filter too, but couldn't get the housing off the cartridge with the tools I have, and with two different filter wrenches that I bought today. So I ordered the proper one from Amazon and it should be here this week, and then I'll do the filter change.
It looks like the previous owner did the oil change in August 2013, and the oil I drained out might have had as much as 16,000 km on it (the maintenance light said the oil could go another 8000km, however when you reset it the number goes up to 24,000km!)
2000 Saturn SC2
(Just installed used 2002 engine)
Out: Unknown oil, MileGuard MO3164 filter
In : Maxlife Nextgen 10W-40 and PureOne PL10241
