Post your latest oil change
'03 Impala 86,078 mi.
Napa Gold 1040, 2 quarts Pennzoil 5w30, Quaker State 5w30, one quart O'Reilly 5w30, remainder of a quart of Mobil Clean 5000 5w30.
I also checked and refilled the water in the battery, and got grossed out by the CAF.
That will be the next thing I replace asap.
Gf`s 1998 Olds 88
Valvoline wb 10W40,AC Delco filter(non-ecore of course). Car has 155,000 miles.
Did a few this weekend, all cars belonging to my brother's.
2000 Ford Taurus- 4.5qts 15w40 Delvac,.5qt MMO. Motorcraft FL400S. 167,000 miles.
2006 Chevy Equinox- 4.5qts 5w30 Valvoline Synpower. Purolator PL10111. 113,000 miles.
2007 Ford F150- 5qts MC5000 5w30, 1.5qts PP/PU mix, .5qt MMO. Motorcraft FL820S. 51,000 miles.
Wrangler - 4 1/2 qts Valvoline + Purolator
Grand Cherokee - 6 qts Supertech + Purolator
Both vehicles are in the ARX rinse phase.
Mazda RX-8 / 5 Quarts Pennzoil Ultra 5W-20 / Mobil 1 Filter (can't get all 7 quarts out because of the darn oil coolers).
Hopefully the old PYB, PU and Mobil 1 oil filter play nice together.
Changed oil in the Go-Kart my brother bought for his kids last year, has a Tecumseh 6 hp OHV engine. Used the MityVac to get the old oil out- age, brand, weight unknown- but it sure looked bad! The air filter was the worst thing I've ever seen, super filthy, big hole knocked through it, wire screen torn through- but Ace Hardware came to the rescue, had the right one in stock!
Refilled with:
Shell Rotella 15w40
1 oz Lube Control
And gave it a new air filter!
2011 Mustang (v6)
Pennzoil Platinum 5w20
Napa Gold 7502 filter
first change (only 1400 miles on factory fill). Sounds good and feels good on first run.
I'll be changing the 03 Santa Fe before too long and I think I'm going to with PYB instead of the high mileage. It had 110,000 miles and no leaks and no signs of burning oil.
1999 Buick LeSabre 3.8L series II engine.
110,860 miles...
4 qts Delo 400 LE 15w40 - it's in the high 90's here.
Drained and reused the AC Delco PF47 oil filter with 4,300 miles on it.
First run on this oil and reusing a filter, we'll see how it goes...
