Post your latest oil change
5hp techumseh lawnmower
20 oz of proline straight 30 weight
also changed a friends 1997 xj cherokee 6 quarts of supertech 10w-40
suoertech filter st-16
'96 Ford Taurus
3.0L V6 161,560 miles
5 quarts Pennzoil Platinum
NAPA Gold #1516 filter
Can't kill that old Ford 3.0L :)
1998 E36, Dinan M3,6 qts 0-30 GC, factory filter, 7k oil change, 145K total miles, avg 27mpg.
2000 E39, M5, 7 qts 0-60 Castrol, factory filter, 9K oil change, 42K total miles, avg 23 mpg.
2008 Rav4, 6 qts Peak 5-30, facory filter, 5K oil change, 20K total miles, avg 24 mpg.
1996 Tacoma V6, Penz Truck and SUV 5-30, factory filter, 5K oil change, 189k total miles, avg 22 mpg.
Will hopefully be this weekend at my inlaws' while "he's" up in the air getting a wheel hub assembly replaced.
5w30 PY, Qs, and O'Reilly regular mixture since that's what I have on hand.
Wife's 2009 Torrent GXP: 5.5 qts of Havoline Synthetic 5w-30, SM rated, and a Fram 10060 Extended Guard filter.
I ran the OLM down to 29% (6925 miles OCI), and the high feature V6 had no detectable oil consumption over that period.
99 S-10: 1 quart Pennzoil 5w-30 synthetic SJ rated ( the old stuff with Pennzane ), 2 quarts Pennzoil 5w-30 synthetic SL rated, and 1 quart Havoline 5w-30 SM rated mineral oil, and a SuperTech ST3387A filter. This got rid of some old odds and ends I had lying around.
2001 Ford focus, 2.0l 16v, used 4.5 quarts of Chevron Supreme 5-30 and a ST Oil filter.
My 2008 Pontiac G8: 7 qts Havoline Synthetic 5w-30, SM rated, and an AC PF2919 cartridge filter.
I ran the OLM down to 44% (5067 miles OCI), and the high feature V6 had no detectable oil consumption over that period. The oil I replaced was SL/GF-3 rated and I was uncomfortable going more than 5K miles on it.
This is the last of my Havoline synthetic stash from the great Advance Auto Parts $1/quart blowout.
1994 Silverado 5.7L Rotella 15w-40 - AC Filter (116k miles)
2001 Cavalier 2.2L QS 5w-30 - AC Filter (120k miles)
2006 Caravan 3.3L PU 5w-20 - Mopar filter (75K miles)
2008 TRX420 ATV (4x4) Rotella 10w-30 - Honda filter (1K miles)
Planning on UOA for the Caravan & Silverado.
In the last couple of weeks:
2003 Pontiac GA 2.2 ecotec 60k, M1 EP, purolater cartridge
2001 Saturn S/C 122k, M1 Fram T/G
2007 Grand Prix GT 47k, PZ Ultra, Pure1
2003 Honda Civic, 58k, Valvoline Synpower, Fram T/G
2002 Pontiac GA 3.4 61k PPlatinum, Pure1
The only non-synthetic I use is in the lawnmower. :)Can you guess which car is mine?
The key words to my busy driveway? Rhino ramps.
'97 Aerostar, Tuesday.
168K.
Second run of Havoline 10W-40 DS, bought on clearance last spring from Wally, Puro classic filter.
Was going to use either Tection 15W-40 or Maxlife 10W-30, but decided to run through the three changes of the Havoline I have.
I will then go through the four changes of Maxlife I have on hand.
The thing has used more oil than it has in the past for the past two changes.
This may just be age and miles, but I will check out the PCV system and see what I find.
2009 Solstice: 5 qts GTX 5-30 SM rated mineral oil and a Purolator Classic filter (L15436?).
Car has about 2.5K miles on it, previous oil in the sump was about 10 months old.
