Post your latest oil change
5hp techumseh lawnmower
20 oz of proline straight 30 weight
also changed a friends 1997 xj cherokee 6 quarts of supertech 10w-40
suoertech filter st-16
'96 Ford Taurus
3.0L V6 161,560 miles
5 quarts Pennzoil Platinum
NAPA Gold #1516 filter
Can't kill that old Ford 3.0L :)
1999 Ford F-150 XLT SuperCab 5.4L
110904 miles
7 qts. Formula Shell Full Synthetic 5W/20
Pro-Tec 159 Filter
1998 E36, Dinan M3,6 qts 0-30 GC, factory filter, 7k oil change, 145K total miles, avg 27mpg.
2000 E39, M5, 7 qts 0-60 Castrol, factory filter, 9K oil change, 42K total miles, avg 23 mpg.
2008 Rav4, 6 qts Peak 5-30, facory filter, 5K oil change, 20K total miles, avg 24 mpg.
1996 Tacoma V6, Penz Truck and SUV 5-30, factory filter, 5K oil change, 189k total miles, avg 22 mpg.
Will hopefully be this weekend at my inlaws' while "he's" up in the air getting a wheel hub assembly replaced.
5w30 PY, Qs, and O'Reilly regular mixture since that's what I have on hand.
Wife's 2009 Torrent GXP: 5.5 qts of Havoline Synthetic 5w30, SM rated, and a Fram 10060 Extended Guard filter.
I ran the OLM down to 29% (6925 miles OCI), and the high feature V6 had no detectable oil consumption over that period.
99 S-10: 1 quart Pennzoil 5w30 synthetic SJ rated ( the old stuff with Pennzane ), 2 quarts Pennzoil 5w30 synthetic SL rated, and 1 quart Havoline 5w30 SM rated mineral oil, and a SuperTech ST3387A filter. This got rid of some old odds and ends I had lying around.
2001 Ford focus, 2.0l 16v, used 4.5 quarts of Chevron Supreme 5-30 and a Super Tech Oil filter.
My 2008 Pontiac G8: 7 qts Havoline Synthetic 5w30, SM rated, and an AC PF2919 cartridge filter.
I ran the OLM down to 44% (5067 miles OCI), and the high feature V6 had no detectable oil consumption over that period. The oil I replaced was SL/GF-3 rated and I was uncomfortable going more than 5K miles on it.
This is the last of my Havoline synthetic stash from the great Advance Auto Parts $1/quart blowout.
1994 Silverado 5.7L Rotella 15w40 - AC Filter (116k miles)
2001 Cavalier 2.2L Quaker State 5w30 - AC Filter (120k miles)
2006 Caravan 3.3L Pennzoil Ultra 5w-20 - Mopar filter (75K miles)
2008 TRX420 ATV (4x4) Rotella 10w30 - Honda filter (1K miles)
Planning on UOA for the Caravan & Silverado.
In the last couple of weeks:
2003 Pontiac GA 2.2 ecotec 60k, Mobil 1 Extended Performance, purolater cartridge
2001 Saturn S/C 122k, M1 Fram T/G
2007 Grand Prix GT 47k, Pennzoil Ultra, Pure1
2003 Honda Civic, 58k, Valvoline Synpower, Fram T/G
2002 Pontiac GA 3.4 61k PPlatinum, Pure1
The only non-synthetic I use is in the lawnmower. :)Can you guess which car is mine?
The key words to my busy driveway? Rhino ramps.
'97 Aerostar, Tuesday.
168K.
Second run of Havoline 10W-40 DS, bought on clearance last spring from Wally, Puro classic filter.
Was going to use either Tection 15w40 or Maxlife 10w30, but decided to run through the three changes of the Havoline I have.
I will then go through the four changes of Maxlife I have on hand.
The thing has used more oil than it has in the past for the past two changes.
This may just be age and miles, but I will check out the PCV system and see what I find.
2009 Solstice: 5 qts Castrol GTX 5w30 SM rated mineral oil and a Purolator Classic filter (L15436?).
Car has about 2.5K miles on it, previous oil in the sump was about 10 months old.
