For the Wife's new 2023 Crosstrek. OCI Número Dos.
Picture or it didn't happen!
2014 Chrysler Town and Country with 106,908 miles.2014 Chrysler Town and Country
102,307 miles, 5460 miles on the oil
Out: Havoline Pro DS 5w-30
Mopar filter
In: Havoline Pro DS 5w-30 and 1 quart Supertech 5w-30
Mopar filter
I dumped a quart of the Havoline in before I realized I hadn’t put the drain plug back in…..
Part of me finds it funny how some of us leghump a particular brand. For the first 15 years I beat the **** out of cars it was all Castrol.2014 Chrysler Town and Country with 106,908 miles.
4600 miles on the oil.
Changed because I’ll be busy at work the next two months and won’t have time.
Out: Havoline 5w-30 6 quart box oil and Mopar Filter.
In: Valvoline Max Life 5w-30 with Mopar filter.
Only reason for the switch is price, though I prefer to use Valvoline products.
Can I get a AMEN!Part of me finds it funny how some of us leghump a particular brand. For the first 15 years I beat the **** out of cars it was all Castrol.
Then I started seeing Mobil 1 as the factory fill on cars I dreamt about (911 GT2 RS etc.), and I never looked back. I continued to beat the **** out of cars and never had an oil related issue.
It isn't marketing for me, I'm loyal to Mobil 1 through and through. I've developed a weird and deep interest in engine protection that only a few niche individuals such as yourselves understand.
My wife and "regular " friends think I'm a little crazy but respect my opinions because the info that I propose is gleaned from hours of reading countless threads with pertinent factual content, with as much ******** as possible filtered out.
Still so much to learn though, like why some advocate going thicker all the time while not seeming to care about how it affects oil pressure and gasket longevity.
I love this site![]()
The oil pump pressure relief controls the max oil pressure the engine sees, regardless of the oil viscosity. Just think how thick oil is when it's 0F outside.Still so much to learn though, like why some advocate going thicker all the time while not seeming to care about how it affects oil pressure and gasket longevity.
Also since the pressure is dictate by the bearing clearances anyway, isn't there no effect on the gaskets either way?The oil pump pressure relief controls the max oil pressure the engine sees, regardless of the oil viscosity. Just think how thick oil is when it's 0F outside.
Most gaskets are not under any kind of oil pressure, but if there was some that were, they better be designed to take the max oil pressure the pump relief is designed to control, plus a safety factor above that.Also since the pressure is dictate by the bearing clearances anyway, isn't there no effect on the gaskets either way?
I think I have a filter that you could use. I’ll PM you if I find it96 chevy c1500 4.3
past due 6149 miles
out super tech 10W30
in pennzoil YB 10W30
fram ph3980 filter.
