Post your latest oil change
For my truck, (1991 Ford F-150 5.0 V-8), I use Mobil 1 High Mileage Full Synthetic 10W-40.
For my Jeep, (2015 Jeep Grand Cherokee 5.7 HEMI V-8), I use Pennzoil Platinum Full Synthetic 5W-20.
For my Toyota, (2018 Toyota Camry 2.5, 4-Cylinder), I use Mobil 1 Full Synthetic 0W-30).
I change oil and filter every 6 months, regardless of mileage. (Probably too often).
If you're not doing constant short trips, a once a year OCI if the mileage requirement isnt' met would be fine. Most car makers these days say you can go up to 1 year OCIs if the mileage is below their OCI requirment. Plus you are in AZ which isn't very humid, which is a plus for extending OCIs because there will be less possibility of water contamination from combustion in the oil.
2010 4.0 V6 Tacoma
46,729 miles
OCI: 2,511 miles (4/29/20 to 5/14/21)
Out: VME 5w30, Toyota 90915-YZZD3
In: 5.5 quarts of VME 5w30, Mobil 1 M1-209A
2010 Tacoma
50,810 miles
OCI: 4,081 miles (5/14/21 to 4/10/22)
Out: ^
In: 5 quarts of Mobil 1 Extended Performance high mileage 5w30 + 0.5 quarts of Mobil 1 Annual Protection 5w30, 90915-yzzd3 & 90430-12031 (crush washer).
I drained and refilled the trans for the first time. I drained out just a touch over 2 quarts of factory fill WS, these are known to be under filled from the factory. It was still pretty red but starting to get a slight brownish color to it. I refilled it with 2.75 quarts of WS plus about 14 ounces of Lubegard Platinum, totaling 3.2 quarts. I also sucked out the power steering reservoir and refilled it with Supertech Mercon V.
03 Pontiac vibe, 193k miles
Out: Castrol edge HM 10w30, ac delco ecore filter. 7k miles
In:
'19 Hyundai Santa Fe Ultimate, 2.4L Theta II
OCI: 4953 miles, 8 months
Out: Valvoline Advanced Full Synthetic 5w-20, OEM filter
In: Pennzoil Platinum syn 5w-20, OEM filter
NOTE: Would have continued use of Valvoline, but Valvoline products at my two local Walmarts seemed to be unobtainium. I went with what was available--SOPUS products, not that it will make any difference to the Hyundai.
2012 Impala 159774
Out Pennzoil Platinum 5w30 AC 63
In Valvoline Advance Synthetic 5w30 AC63 Delco oil filter
Vehicle been on Pennzoil for all it's life but Walmart and Advance Auto was empty as all shelves were empty of Pennzoil Platinum only had Pennzoil Full Synthetic
PCV replaced
2 qts oil in 5k.
