Post your latest oil change
2000 Acura 3.2TL
2.5 qts Mobil 1 0W-20, 1 qt Mobil 1 5W20, 1 qt Mobil 1 Extended Performance 5w30
Mobil 1 oil filter
1980 Dodge van. Rebuilt to be a 20 passenger van. Longer, wider, and heavier than a standard van. It has been sitting in a pasture belonging to his father for a few years until a friend rescued it. We have been working on it on the weekends.
He is using it to haul stuff and people around for a homeless ministry he does on Sundays. And he must be doing God's work cause the Bus hasn't abandond hope and stranded him somewhere. It really is an amaizing piece of work.
Right now it has 1 bottle Auto RX in it, 5 quarts of Quaker State Green bottle 10w30, and 1/2 quart of Mobile Drive clean to top it off. With a Mopar filter.
His father told him when he picked it up "yeah I think I did ONE oil chang on it ONCE." I figure it is a good Auto RX candidate.
It has a 5.2 Liter 8 cyl engine with a 2 barrel carb and a 4 gear auto transmission, 3 forward, 1 reverse. The only dial that works is the aftermarket Tempature guage. No Tach, Speedometer, Odometer, or fluid levels. We figured out it had a 33 gallon tank by filling it up, and we figured out we needed to replace fuel lines by pulling off the engine covers and looking at the leaks.
I probably need to start a thread on this Van/Bus and keep you guys informed.
Maintenance day for the 07 3.0L Accord. 19.6k miles on the clock, 6100 mi. on dealer Honda(MC5k) oil and filter. Dang OLM only at 30% but it had been 10&1/2 months and I could take no more. Normally would change at 5k/6m but the OLM is rather convincing.
Quaker State Horsepower Syn 4.5qts.*
Pure One Oil Filter PL 14610
New crush washer
Fram Air Filter 9600, half the cost of Honda. Looked fine. tricky to put in until you get technique.
Discount Tire Rotation
*Notes
First synthetic oil change ever, in many years DIY OC
I will go the distance (or very close) this time using OLM OCI.
Drain plug was a pita to get off because of dealer tightening. Glad I had a 6 point socket, and hammer tap to ratchet finally freed it up.
First oil filter on Honda I've had with base up (verticle) position. ADBV should be no factor.
Reseting Maintenance minder, OLM, took some reading. lol
A successful Honda maintenance day.
The little Saturn has a SuperTech filter and Quaker State "Torque Power" synthetic 5w-20.
Big Saturn, Pennzoil Platinum 5w-20 with an Mobil 1 filter.
Originally Posted By: lucerne06
4.3 ??? are you sure ???
4.3 L sump down here, a quart is close enough to a litre...
Just changed the oil this morning in the Focus. Had 9600 on Mobil 1 5w30, Changed to Mobil 1 5w30 Extended Performance. will run that for at least 11,000 miles.
As of April 2009:
2003 Buick Park Avenue, non-supercharged 3.8L engine
5 quarts of Castrol GTX, 5w30; maintenance dose of Auto-Rx
Purolator PureOne filter
At 3K miles, added 1 pint of SuperTech 5w30 conventional
2007 Chevrolet Impala 3.5L. 4 quarts of Valvoline Durablend with a Bosch oil filter. I do intervals at 10% of the OLM, which translates to between 4,000 and 5,000 miles, depending on how many cold start/short trips there was.
Maxlife Synth. Blend 5W30 with a Purolator Premium Plus filter and a 3 Oz of ARX.Planning on a 4000 Mi OCI
Just finished up our 98 Blazer. 4.3L 226,000 miles
3.5 quarts Chevron Supreme 10w30, 1 quart of Valvoline 5w30 with a Proline Filter. Total cost of oil change was about 8 bucks.
2004 malibu classic 2.2 (4cyl) this morning at 83,500mi
synpower 5w30 and a napa gold 7082
good for another 5000 miles
