Post your latest oil change
Did 2 oil changes 2 days ago.
Eclipse is running Mobil 1 High Mileage 10w30 with a Mobil 1 oil filter
535i is running Mobil 1 10w30 with a Purolator oil filter
TODAY....2005 Toyota Camry 2.4 46300 miles.
dumped out Mobil 1 and Mobil 1 filter at 7 K oci miles and it was very black.....all highway miles.
Put in PP and Mobil 1 filter and will run again to around 7 k , all highway.
BOB
I've used Mobil 1 10w30 in my truck for 17 years. This weekend I went with Pennzoil 10w30 HM, and a NAPA Gold filter. Since I'm only putting around 2K miles a year on it now, I figured synthetic was no longer necessary. Not sure if I'm gonna stick with the PZ, but thought I'd give it a try. Not sure if I needed HM either, as the truck doesn't leak any oil or have any other problems.
1995 Acura Integra LS
Castrol GTX 5w30
Purolator Premium Plus 14459 oil filter
I was going to run the Pennzoil 5w30 I had in there to 5,000 miles but I had the valve cover open to adjust the valves and wanted to change it out because of the silicon (hondabond) used on the gasket and the dirt/dust that may have been introduced. It only made it to 3,920 miles or so.
2002 Roush Mustang 4.6
AMSOIL Signature Series 0w30 and EaO filter.
2003 Dodge Neon SE 2.0
Pennzoil Platinum 5W30 and Fram Extended Guard filter.
1986 Ford F150 5.8 HO
PartsMaster HD30 and WIX filter.
2008 Civic
Pennzoil Platinum 5w-20
RP 10-2867
Now that I have over 15,000 miles on the car, I'm planning on running a manufacturer-approved oil for a warranty period OCI and getting my first UOA. Hopefully, if there's a developing problem in my engine I'll see some sign of it on paper and be able to fix it within the regular warranty period.
2007 Toyota Tacoma
Valvoline Synpower 5W-20
OEM (Denso) 90915-YZZD1 filter
2000 Acura Integra
Royal Purple 5w30
NAPA Gold 1334 filter
1969 VW Microbus
Castrol GTX 20W-50
Baldwin B243 filter
2008 Ford Mustang/Lincoln Mercury Dealer changed oil to:
Motorcraft 5w30 Synthetic Blend/Motorcraft Oil Filter
June 17,2009/"Praise The Lord" back to OEM OIL & FILTER!!!!!!!
