Post your latest oil change
2010 Pontiac Vibe GT 2AZ-FE FWD
31,945km
Out: Unknown Fill & Defense Garbage Filter
In: Super Tech Full Synthetic 5W20 & Fram FPS3600
Notes: Unknown clicks on oil, but previous owner said only 300km at time of pickup and changed June 2020. Every fluid is being changed, brakes, filters, and factory tires replaced.
(Yes, odometer was Provincially certified on April 2021 in two provinces) ;)
2012 Ford Focus SE - 61,641 miles, one year and 1,476 miles on OCI - college student that didn’t drive very much…
out - Castrol Magnetec 5w-20 and Motorcraft FL 910S
IN - Castrol Magnetec 0w-20 and Motorcraft FL 910S
2013 Chevy Equinox AWD w/ a 2.4L
Out: Kirkland 5W-30 and PF457GO
In: QSUD 5W-30 (rediscovered under workbench) and PF457GO
Interval: approx 3,800 miles of hard winter driving
My Alaskan 2006 Chevy Silverado 4WD w/ a 5.3L Gen III L59 Engine (no body rust as salt is NOT used in southcentral Alaska)
Out: QSUD 5W-30 and a Wix 51522
In: Kirkland FS 5W-30 and a leftover Baldwin B31
Interval: 4,000 miles of hard fall and winter driving
I really like those Quaker State and new Kirkland 5W-30 oils and their pricing.
2014 Subaru Forester 6MT 2.5L NA
ODO: 78,420
Estimated hours on oil: 64
Miles on oil: 2,625
Out: 5.5qt of mix (7 parts Delvac 1300 15w-40 + 3 parts Mobil 1 EPHM 5w-20) + 2 pt rislone high mileage concentrate
In: 1 pt rislone high mileage concentrate + 5qt Mobil 1 0w-40 Euro
Off: XG7317
Estimated hours on filter: 84 +64 = 148
Miles on filter: 3,195 + 2,625 = 5820
On: XG7317
For the trailing oil: car consumed 1 pt, replaced with rislone 4102. Did not show signs of consumption for the next ~380 miles. Consumption seemed to slowly return after commuting to and from work; added 1 pt of 70:30 Delvac:M1EPHM mix. Consumption continued at same pace; replaced 1 pt with rislone 4102 for last 80 miles (ODO 78,340) for more severe final cleaning. Changed at Walmart Auto.
From what I can tell, I don't see oil leaking, and the tube connecting the PCV valve to the intake manifold has some oil in it. (no oil around PCV valve threads, no pooling on engine; oil only in the tube.) I suspect stuck compression rings due to either varnish or carbon. Looking to install a catch can on this OCI. I am not sure how well the PCV baffling is, but this should help keep oil from being sprayed into the cylinder. Most people's remedies on subaruforester(dot)org involve thicker oil (either additional oil cooling or M1 0w-40 euro) to cut consumption rate in half, but no one has tried PCV replacement or the catch can. I have already cleaned the PCV valve last time, so I don't suspect that. Also added Gumout AIO fuel cleaner in gas this time for elevated PEA.
Despite this, the optimism for restabilizing a low consumption rate (1pt-1qt in 10km) is not strong.
ODO: 78,420
Miles on oil: 2,625
Off: XG7317
On: XG7317
Have you considered trying the bg epr/moa kit for ring cleaning? Its supposed to work well in GM Ecotec 2.4s with consumption problems due to dirty rings. Might be worth a try.
I have, actually. Its probably going to be my last option though; I'm not sure how aggressive that kit is against seals.
