Post your latest oil change
2016 F-450 6.8L 8,100 miles
Out: Motorcraft 5w30, Motorcraft FL820S
In: Napa Syn 5w30, Napa Platinum
2008 Honda Accord 2.4
140k miles
Supertech Synthetic 10W30, Fram XG7317
Drain plug 29 ft lbs
2005 GMC Envoy 4.2 Vortec
152k miles
Supertech 10W30, Fram PH9837
Drain plug 19 ft lbs
2008 Chevy Trailblazer 4.2 Vortec
111k miles
Supertech 10W30, Fram TG9837
2000 Suburban
240,000 miles
Out: ACDelco 5w30
ACDelco PF46E
In: Same
3,000 OCI
2014 Lincoln MKX AWD
100,000 miles
Out: Motorcraft 5w20
Motorcraft FL 500s
In: Same
5,000 OCI
2015 Lexus IS250 AWD
50,000 miles
Out: TGMO 0w20
Toyota yzza5
In: Same
5,000 OCI
I'm out of supplies for my suburban, am thinking of changing to Havoline Smart Change 5w30, as she takes 6qt. ACDelco is non existent in my area and too expensive online. Also may go to Smart Change 5w20 for MKX, also holds 6qt.
Wow, you win today's award for most loyal follower of OEM oils.
Happy New Year and I'll bet you were chilled, after doing three oil changes in northerly Ohio in January.
It was a nice day yesterday here in Michigan, near 50 degrees on my front porch thermometer.
Happy New Year! Weather has been mild here so far, around 50 and sunny yesterday. Only change the suburban outside, others fit in the garage nicely for maintenance. Yes, love me some OEM, wipers, filters, plugs, brakes etc.. with online purchases, can be just as cost effective as in store, just my preference, to each his own!
2013 Bmw 750IX N63TU engine.
Out 9.5 Liter Bmw oem 0w30 4800 miles.
In 9 Liter Liqui Moly Top Tec 4100 5w40 oil and 2x300ml Liqui Moly Cera tec.
[Linked Image]
Originally Posted by Villalobos
2000 Suburban
240,000 miles
Out: ACDelco 5w30
ACDelco PF46E
In: Same
3,000 OCI
100,000 miles
Motorcraft FL 500s
In: Same
5,000 OCI
50,000 miles
Out: TGMO 0w20
Toyota yzza5
In: Same
5,000 OCI
Wow TGMO and Motorcraft!
I think you'll like the smart change box.
Every one of my oil changes looks the same on paper... only the vehicle changes.
2005 Ford Five Hundred 99Kmi
2008 Ford Edge 85Kmi
2019 Ford Transit Connect.........
Every 5000mi......
Federated Auto Parts 5w-20 Syn Blend, Federated brand filter........ Rinse and repeat....... year after year after year.
1991 Bronco, 5.8L, x56,436mi
Out: Castrol Magnatec 10w30, Bosch D+
In: 10w-30 5qt Castrol Edge, 1qt Castrol Magnatec, Bosch D+
[Linked Image from i.imgur.com]
Fiancee's 2018 Civic LX Hatchback 1.5T 6MT
Out: Castrol EDGE 0W-20, OEM Honda Filter
In: Valvoline Modern Engine 0W-20, OEM Honda filter
Left the Castrol EDGE in a bit longer than I meant to. A little over 6200 miles. Plan is to do 5000-mile OCIs at most. Got away from me this time.
I did take a sample and will be sending to the lab. She was working only 3 miles from her job during much of the time this oil was in, so I hate to think how much fuel is in it.
Now she has a different job and she's more like 12 miles or so away. So, the oil shouldn't get diluted with fuel as much.
Sure was nice knowing I only paid $2/quart for that oil (Auto Zone clearance).
2016 Buick LaCrosse, V-6
Out: Unknown oil from Subaru dealer, 4.5 months/approx. 4000 miles on it, at 38,170 mi.
In: dexos 5w30 (not sure of brand, as my regular mechanic did the change -- I told him any dexos in the right viscosity), AC Delco oil filter. (I swapped him back the 0W-40 Edge and the two Mann filters I'd bought for the BMW just before it was totaled, so my only cost was his labor.)
Also had the tires rotated and a cabin filter installed. I'll do the engine air filter this month myself, so that I can draw a baseline at 40K miles.
2018 Subaru Legacy
9300 Miles
Out Subaru fill (from dealer)
In Mobil 1 Advanced Fuel Economy 0w20 and Amsoil Filter
2002 Chevy Silverado w/5.3 LM7 engine. 197750 miles
Out:
Supertech 10W30 conventional and AC Delco filter
In:
Carquest 10W30 High Mileage and Purolator filter
Also changed my fuel filter and bought a can of white lithium grease for the garage.
Purchased at Advance Auto and was able to stack a $20 Speed Perks coupon with a 25% off online promo code. Cost me less than $23 for all the above.
04 camry 2az-fe 2.4L 4 cyl
Miles on unit 218,000
Short OCI due to some engine maintenance work.
OUT: Mobil 1 High Mileage 10w30 + premium guard filter
in : 1 qt supertech 10w30 conventional + 1 qt Mobil 1 High Mileage 10w30 + 2 qts Havoline High Mileage Synthetic Blend 10w30 + an old carquest (Purolator) basic white can filter from 2014.
Lol clearing out old stock...
11 Traverse
Out: Frankenblend and Ultra Power filter.
In: Rotella Gas Truck and Delco filter
Got some done on the ole Traverse today. Oil change, transmission fluid change, rear diff oil change, and air filter.
I will post the oil filter in the sub section, it was pretty awful.
2012 Acura TL SH-AWD 6MT
94,180 miles
2858 miles since last oil change
OUT: Quaker State Ultimate Durability 5w30 full synthetic
IN: Pennzoil 5w20 Pure Plus Ultra Platinum
Did not change Fram ultra oil filter
2013 Mazda 3 2.0L Skyactiv
68900 miles
6000 miles on oil
OUT: Supertech 0w20 Full Synthetic Mobil 1 Oil Filter
IN: Pennzoil Platinum 0w20 Fram Core 6607 Filter
2013 Audi S4 6MT
44,450 miles
5,500 miles on the oil from April 2018.
OUT: Castrol 5w-40 OE Professional.
IN: Motul Xcess 5w-40.
Trying to go every 5,000 miles for nice easy numbers. Next change at 50,000 miles. Sticking with Motul for this car.
2017 Ram 1500 4WD Bighorn 5.7L
OCI: 5736 miles, 9 mos.; OLM at 43%; no oil added during OCI.
Out: Pennzoil Platinum 5w-20, Fram TG10060
In: 6 qt. Valvoline Advanced Full Synthetic 5w-20 & 1 qt. (leftover) Pennzoil Plat. 5w-20 (7 qt. total w/filter). Fram TG10060 filter.
