Post your latest oil change
2015 GMC Terrain V6
Out: 6qt Pennzoil Platinum 5w30, Supertech ST10575 filter
in: 6qt Havoline Pro DS, AcDelco PF63E filter
I switched back to OEM filter for this engine since GMC now wants a 22 psi bypass valve pressure for this engine, and a lot of the after market filters don't meet that.
google 17-NA-157 to see TSB
2012 Toyota Tacoma 4x4. 2.7L 4 cylinder (2TR-FE). 89,720 miles.
OCI: 5,000 miles
OUT: Mobil 1 0W-20 Economy ( 5 qt.)
FILTER: Toyota 90915-YZZG2
IN: Mobil 1 0W-20 Extended Performance ( 5 qt.)
FILTER: Toyota 90915-YZZD1
Sent to Blackstone Laboratories. First OA for this vehicle.
2017 Ford Fusion 2.5 with 10K OCI.
Out: Mobil 1 0w20 Extended Performance
In: Mobil 1 0w20 Extended Performance
Filter: MC FL910S
2004 Toyota Corolla
Out Havoline Pro Ds 10-30 Purolator PureOne
In Pennzoil 5w-20 Platinum HM ST4386
6764 mile OCI
[Linked Image]
[Linked Image]
[Linked Image]
The Purolator one held up just fine. Haven't had a Purolator failure since I started using before 2010. No ripe, no cuts, no tear and no errors.
I didn't really care for the spacing on the filter but it held together. WIX oil sample went to the Lab today. Well see how it held up lots of people on here think Havoline is not a 7K Mile oil.
The is my $7 OIC SOCUS did refund me on this so I'm running one for three with them.
The Mann filter a bit of a disappointment Made in China!
Another disappointment my highest oil usage on the Corolla 1/2 quart in 6764 miles.
Originally Posted by JohnnyJohnson
2004 Toyota Corolla
6764 mile OCI
[Linked Image]
[Linked Image]
[Linked Image]
Johnny: what vehicle did the MANN go on?
Looking forward to UOA :^)
I just checked and the Mann filter appears to be for the Corolla. They have them on Amazon for around $15 plus $10 shipping. Not avail on rockauto.
2008 Tundra 5.7
Out: Unknown fill and filter from previous owner. about 10k OCI
In: Supertech High Mileage Synthetic 0w-20 and Toyota filter
2017 Subaru Crosstrek
Out: Kendall GT-1 MAX 5W30 and blue Subaru oil filter.
In: Kendall GT-1 MAX 5W30 and blue Subaru oil filter
7,023 miles on this OCI. I am mailing out oil sample tomorrow for analysis through NAPA, oil analysis laboratory in Portland, OR.
No oil added between OCI, as the oil level never changed.
Look forward to seeing the data.
2013 Honda CRV
Out: Pennzoil Platinum 0w20 and TG7317
In: 2 QT Valvoline 0W20 FS 3 QT Super Tech 0w20 Full Synthetic and TG7317
7,7XX miles on oil
2014 F150 STX Sport 5.0
Out: Pennzoil Platinum Pure Plus 5w20
Off: Motorcraft fl500s
In: Valvoline Advanced Full Synthetic 5w20
On: Motorcraft fl500s
2013 Altima 94300
Out Valvoline Advanced 0w20 STP filter
In STP 0w20 with STP filter
5k interval
2012 Impala 140798
Out Pennzoil Synthetic 5w30 AC Delco filter
In Pennzoil Synthetic 5w30 AC Delco filter
5k interval
2010 Odyssey with 126,730 miles
5,007 miles covered in 88 days ...³
Out: Mobil 1 High Mileage 5W-20 and Mobil M1-110A filter
In: Mobil 1 High Mileage 0W-20 and Honda OEM filter
Also did a tire rotation and transmission fluid drain and fill.
Out: Valvoline MaxLife ATF (9,606 miles in service since 5/15:19)
In: Same
2019 Toyota 4Runner with 2256mi. I always do an oil change early on for no other reason than it makes me feel better. Finally after agonizing over oil choices I just picked Quaker State Ultimate Durability 0W-20 with a stock Toyota filter. Also took this opportunity to upgrade the plastic filter housing to the aluminum one. I'll probably run this for 5K then move to longer OCI's after 7500 or so.
2010 Honda Fit Sport
52586km
OCI: 4942km
Out & Off: Quaker State Advanced Durability 5w20 & Bosch 3323
In & On: Quaker State Advanced Durability 5w20 & Bosch 3323
Also switched over to winter tires and did a transmission drain & fill (last one done at 25000km)
Out: Honda ATF DW-1
In: Honda ATF DW-1
