Post your latest oil change
2006 Dodge Grand Caravan SE 3.3L 257428 mi.
Out: Havoline conv. 10w30 3 make up Qts Fram XG16 OCI 8323
In: Chevron supreme 3 Qts 10w30 2 Qts 20w-50 Fram XG8A
8.3K is a long-long time using conventional inside an old, tired engine. That new oil may turn the dipstick black in the first few hundred miles.
The 20w50 should help slow consumption.
It usually takes about 7-8 k before it's dark enough to bother changing. I am adding 60% of the sump capacity of new oil in every oil change
2017 Honda Ridgeline
9K on sump MM telling me I was between 5 &10% but it was dropping quickly.
Topside oil change - no filter change. (yes I know that isn't what B1 is I already changed the break-in filter. )
12 minutes to suck it out and pour it back in - with a bigger mouthed funnel I could have made it in 10 min.
Idemitsu 0W-20 GF5 - 20 bucks.
UD
https://www.youtube.com/watch?v=c-URwerwX6U
17 Kia Sportage
Out: Mobil 1 Extended Performance 5w30 + M1-104A
In: Castrol Magnatec 5w30 + K&n HP1004
Mudboat with a 502 Chevy
Valvoline VR1 20W50, Wix 51061
runs about 65 mph with one man, weve gotten it to over 70 mph in shallow water
Old Yamaha EF1000 generator
1/4 of a quart of Castrol GTX 10W40
Air compressor with a 10 hp briggs
1/2 quart Castrol GTX 10W40
2017 Kia Rio EX, 1.6L Gamma
Out: 3qt Delvac 1300 15w40 + 1 qt Rotella T5 15w40
Hours on oil: 104
Est. miles on oil: 4575
ODO@change: 67910
Off: N/A
Hours on filter: 104
Est. miles on filter: 4575
In: 3qt Delvac 1300 15w40 + 0.5 qt Pennzoil Platinum High Mileage 5w20
On: N/A (starting run 2 on filter)
2015 Chevy Equinox 2.4 Ecotec
45,500 miles
Napa Dexos 5W30 syn, Fram XG9018
drain plug 18 ft lbs
2005 Dodge 2500 5.9 Cummins
433,964 miles
Valvoline Premium Blue 15W40 CK4, Napa Platinum 47620
drain plug 37 ft lbs
1998 Toyota Camry CE, 2.2L 5S-FE, 315,000 miles
Out: Miles Lubricants Milesyn SB 5w30 (3,000 miles on oil) / Toyota OEM 90915-YZZF1 filter
In: 2QTS Miles Lubricants Milesyn SB 5w30 + 2QTS SuperTech High Mileage 5w30 / FRAM Extra Guard PH4386 filter
2014 Mitsubishi Lancer
65xxx miles
45xx miles OCI
6 months in service
Out: Mobil 1 5W30
Ecoguard filter
In: Pennzoil Platinum 10W30
Mitsu OEM filter
2019 Subaru Impreza hatchback
5900 miles
Out: Subaru FF/OEM filter
In: Castrol EDGE Extended Performance 0w-20/Purolator Boss filter PBL14615
Installed Fumoto valve.
Will pull sample at 6k to see if 10k feasible.
2018 Honda Clarity PHEV
6800 miles
Out: Honda FF/OEM filter
In: Castrol Edge Bio Synthetic 0w-20/Purolator Boss filter PBL14610
One year OCI expected.
