Post your latest oil change
Auto: 2017 Subaru OB Premium 2.5L; 15330 miles
Out: Pennzoil Platinum 0w20; Fram XG7317; no make-up oil in ~5000 miles
In: Pennzoil Ultra Platium 5w20; Mahle OC1177
I got two done today;
2009 Malibu 2.4 LE5
5 qts. Mobil 1 Extended Performance 5w30, A/C Delco PF458G, No make up oil.
2013 Tahoe 5.3 LMG
6 qts. Mobil 1 Extended Performance 5w30, A/C Delco PF48E, No make up oil
2014 BMW X1 2.0. Drained out the BMW 0w30 along with replacing the cheap Korean made filters the BMW dealer uses. Put in Total 5w40 Quartz 9000 along with a Mann oil and air filter.
2015 Honda Pilot. Was close to tripping the MM at 20%, but going on a trip next weekend so changed it. Valvoline Advanced Synthetic 0W-20, Bosch 3323 filter. About 7,000 miles since the last change.
2004 Sentra 1.8L, 195K miles, unknown OCI
out - black stuff and filter
In: almost 4 quarts SuperTech High Mileage 5w20 Synthetic
whatchacallit synthetic filter
Swapped radiator, cleaned it up.
Gonna do a little more, service trans, tires, whatever.
Then it's off to AZ and new owners.
2013 GMC 1500 5.3L 181K kms on truck, 11,000 k kms on oil.
out; Shell RT-6 5W40 & fram TG.
in; Petro-Can HP 15W40 CK-4/SN & Wix, long one that fits the 6.2L engine.
The work van got an oil and filter change today @34049 miles. It's a work provided 2017 NV200. Out went Castrol Magnatec 5w30 with 5500ish miles. In went conventional Formula Shell 5w30 (from the bulk container label) or Havoline 5w30 (according to the receipt and it was a Havoline instant lube). It did not sound better with the new oil vs the old oil (I could tell a huge difference in the engine sound from 6000 mile Mobil 1 5w30 and the new Magnatec). Can't complain, it was $28.88 out the door with a free car wash and "tri color polish / clearcoat protectant / wax" and air dry with free self service vacuum.
This engine sounds like it's literally going to explode at any moment no matter what oil I use, so it is heretofore getting whatever is cheapest, except I'll probably get it changed with synthetic 0w30 for the winter to make it sound less clacky when it's cold.
12 traverse
3.6 v6
Out: unknown, Napa gold filter
In: Mobil super syn dexos 5/30, Napa gold filter
07 f450
6.0 powerstroke v8
Out: Napa universal 15w40, unsure of filter brand
In: Napa universal 15w40, Napa gold filter
2004 Corolla 129693
Out: Castrol EDGE Extended Performance 5w30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w30 Purolator PureOne 3-14-19
WIX UOA sent in.
Engine Air filter changed
Cabin Air filter Changed.
5 SPD gear oil changed Amsoil 75w-90
2019 Hyundai Santa Fe Ultimate 2.4L
Odometer: 2586
Out: Factory fill / OEM filter
In: Valvoline full synthetic 5w30 dexos 1 Gen 2 / Fram XG9688
No oil added over OCI
1st oil change on this vehicle, done early to get any break-in contaminants out.
2018 VW Golf Sportwagen S 4Motion 1.8L
Odometer: 7810
Out: Factory fill/OEM filter
In LiquiMoly Leichtlauf High Tech 5W40 + OEM filter
Sample sent to Blackstone
1st oil change on this vehicle. It's tuned Unitronic Stage 1+ and running a drop-in K&N filter (OMG I can't believe it's still running)
2001 Toyota Camry 2.2L in signature, short-tripped and run hard.
Last oil change 9/29/2018 at 141,236 miles. Changed today 3/16/2019 at 142,615 miles.
Out: Quaker State High Mileage 5w30 and FRAM PH4967
In: SuperTech High Mileage 5w30 and Super Tech ST4967
