Post your latest oil change
2007 4Runner 4.7, 75050 miles
OCI - 5000 miles/11 months
In and out - Mobil 1 0w40
OEM filter
Sent oil sample to Blackstone.
08 Chev Suburban 6.0
Out Pennzoil Platinum: 5w30
In : Pennzoil Platinum 10w30. 172,000 miles
Left the oversized Fram 10575 on it.
I have a broken front stud on the driver side exhaust manifold which I suspect is giving me a cold tick that disappears when it is warm. Just want to check it was a lifter so changed to 10w30 to see If any difference.
First oil change on the '18 Crosstrek.
Interval: 6036 miles, 6.5 months
Oil consumption during OCI: ~0.5 qt, almost all during the first thousand miles. No make-up oil added.
Out: Subaru factory fill (took a sample, will send it in to NAPA this week)
In: Idemitsu Zepro Eco Medalist Advanced Moly 0W-20 (got two 5-qt jugs for $21/ea on Amazon a while back)
I did a conventional drain through the drain plug and put on a new Subaru filter and drain plug gasket. While I was underneath there I saw that there is a plastic kinda-sorta skid plate (with a little cutout for access to the drain plug) that should provide a modicum of protection, so maybe next time I'll put a Fumoto valve down there.
I needed a cheater bar to get the drain plug loose - it appeared to have been painted over AFTER being screwed in - but overall the oil change process itself was real easy. I like the top mounted filter. What was a PITA was rotating the tires, because I found to my chagrin that my floor jack couldn't extend far enough to get the tires off the ground - the ground clearance and suspension travel were too much! I ended up using the scissor jack that came with the vehicle to get it up on jack stands, which worked but took forever and a day. On the plus side, I was able to break the lug nuts loose with just a lug wrench, no breaker bar needed. Rust levels on the lug nuts were low despite the first half of this OCI being during road salt season.
Not sure whether I should get a floor jack with more travel, or find a 2x8 or something similar to put under my existing jack.
99 4ruuner 3.4 369k
Out: valvoline vr1 10w30 with wix 51348
In : Castrol Edge 10w40 high mileage with 51338
12 GS350 F-sport 48k
Out: Edge EP 0W20 with oem filter
In : Edge EP 0W20 with oem filter.
was going to change it to 5w20 but didn't have enough 5w20..
The wife's 2018 Chevy Trax
Out : PEAK Full Synthetic 5W30 with an STP Maximum Life ( 15,000 Mile ) Oil Filter
IN : PEAK Full Synthetic 5W30 with an STP Extended Life ( 10,000 Mile ) Oil Filter
6,000 Mile OCI
2016 (maybe '15?) Nissan Sentra 50K, 6K OCI
Out: 4 quarts SuperTech 0w20
In: 4 quarts SuperTech 0w20
Did not swap out Fram Ulta filter; will change next service.
Changed out factory fill/filter on 2018 Jeep Grand Cherokee 5.7L Hemi:
7 Quarts of Pennzoil Platinum and OEM Filter (MO-339)
1,865 Miles
Next change will be 6 months or 5,000 miles whichever comes first
2004 4Runner V6, 177,718
Out: Redline 5w30 and Fram XG3614
In: Pennzoil conventional (old label) 5w30 and Fram PH3614
Oil was in service 6,900 miles over 2 months of driving with most of it towing.
1969 Ford Mustang Mach 1
Out: Pennzoil Conventional 10w30 and junk Performax PO-1 filter (Tearolator jobber, that was tiny compared to the Napa Gold I replaced it with!)
In: 6 more quarts of Pennzoil Conventional 10w30 and a Napa Gold 1515, car rarely sees 1000 miles a year so I change it annually, although the last oil had almost 2 years on it and around 700 miles. Oil still looked really clean but I wanted to get that Tearolator off there mainly!
2004 Nissan Sentra 185K
Out: less than 1 gallon Valvoline MaxLife 5w30
In 3 quarts Valvoline MaxLife 5w30 + 1 quart Mobil 1 5w20 Frankenmix.
No filter change cuz I was too lazy and it's hot today in Silicon Valley.
Next time...
2015 Nissan Sentra. 56K miles on engine. 4700 miles, 4 months on oil.
Out: Valvoline Synthetic 0W-20, Fram Tough Guard filter
In: Valvoline Conventional 5w30, Valvoline filter
Working 60 hours a week makes it difficult to change my own oil, so I took it to the VIOC. It's crazy how much cheaper it is to use synthetic on a DIY job than to pay for a quick lube.
