Post your latest oil change
Originally Posted By: plf
2010 Honda Cr-v, 127,000 @ 7,500
Out : Quaker State Full Synthetic 0w-20 , supertech filter 9688 (white can)
In : Quaker State Full Synthetic 0w-20 , supertech 9688 (white can)
Next one will use Pennzoil Platinum 0w-20 picked up with rebate , and Fram EG 7317 got with rebate.
So how was that Quaker State Ultimate Durability for you and how much top off oil did you have to use for your OIC?
2013 Optima 2.4L. 2.5 qts Pennzoil Ultra Platium 10w30 and 2.5 qts Pennzoil Platinum 5w-40. With 3.5 to 4% fuel dilution it requires thicker oil. If you have a theta 2 engine you need to get a oil analysis with gas chromatography.
2014 M235i, 40,670 miles
1 year/9,629 miles on oil
Out: BMW TwinPower Turbo 0w30 (LL01 FE+), BMW 11-42-8-683-196 filter element
In: Same
Busy day!
2017 VW GTI - 6,518 miles.
Out: Castrol Edge 0w40 - OEM filter
In: Same
5,112mi, 1 year OCI.
2015 Toyota Camry - 18,783 miles.
Out: TGMO 0w20 - OEM Filter (last dealer OC)
In: Penn Platinum 0w20 - OEM filter
4,449mi, 1 year, 1 mo OCI.
Changed the oil in my gf’s 2002 Honda Odyssey. It has 212,000 miles.
Out: two and a half quarts of some thick and nasty sludge
In: Quaker State high mileage 5w30 and a NAPA gold filter.
Also changed spark plugs, air filter, and PCV valve while the oil was dripping.
Not bad for an hour’s work.
2009 Cobalt
Out: Not mine so who knows
In: GTX 5w30 and a Tough Guard filter (cartridge type)
It was fun teaching my friend how to change her oil. The oil life monitor had 3% left and I told her to let me know what it is at at 5000km.
2007 Honda Accord EX-L 3.0 96K
6,000 miles OCI
Out: Castrol EDGE Extended Performance 0w-20
In: Pennzoil Ultra 5W-20
Left the Fram FPS7317 on going for another 6K.
5 HP Tecumseh powered snow blower.
2 year OCI
Out: Mobil 1 Advanced Fuel Economy 0W30 and Rislone ZDDP additive.
In: The same.
Sister’s 2008 Mustang 4.0L
Out: Castrol GTX 5w30 and Motorcraft FL-500S (from quick lube joint)
In: Motorcraft Syn Blend 5w30 and Motorcraft FL-820S
Out came 2.5 quarts? So it was two quarts low? Oh no.
My Tacoma
Out: German Castrol 0W-40 and Fram Ultra with 8,391 miles on both.
In: Mobil 1 Advanced Fuel Economy 0w30 and a Tough Guard.
I had originally planned to go a full 10k on the Castrol but the oil change itch got too strong and I couldn't hold myself back this morning! Especially having bought some oil last weekend and having a stash of TG filters next to my chair from the TSC clearance a few months back. Planning to cut the old filter open as soon as my filter cutter comes in.
2008 f150 KR 2wd
132,951 miles on the truck, 4,738 on oil.
7qts total, no makeup.
Out: left over oil mixture (Maxlife blend 5w30, Magnatec 5w30, MileSyn blend 5w30, Rotella T 15w40), MC 820s
In: Another mixture (4 qts MileSyn 5w30 blend, 1 qt 5w20 ST conventional, 1qt 5w30 ST conventional, 1 qt 10w30 Rotella T5 blend), Blue sparkly Purolator One filter
2014 Buick Regal 2.0T AWD, 63,000 miles
Out: Castrol Magnatec 5w30
In: Supertech Full Synthetic 5w30, NAPA gold filter
Oil life monitor was down to about 19% (7,400 miles.)
