Post your latest oil change
2018 Mercedes-Benz GLC 43 Coupe 3.0 Biturbo 4Matic
OCI = 1,618 miles (Factory Fill)
Out:
Mobil 1 European 0W-40 SN and MB OEM
In:
There was a nice pearlescence to the oil that came out. I would have dumped at 1K as per my normal routine with a new car, but I have to drive from SLC to Houston and did not stop to change the oil.
2013 Toyota Tundra 5.7
Miles on unit: 25,000
Out: 8 1/2 qts. Mobil 1 Advanced Fuel Economy 0w20, 04152-yzza4 filter
6,000 miles, 14 months
In: 8 1/2 qts. Idemitsu 0w-20, 04152-yzza4 filter
Drain plug 30 ft lbs.
Filter housing 20 ft lbs.
Filter housing cap 10 ft lbs.
New o-rings
New drain plug gasket
2010 Nissan Altima 3.5L V6
Miles: 42,235
Out: Mobil 1 or Mobil 1 Extended Performance 5w30, Genuine Nissan oil filter.
8 months, 3500 miles.
In: Mobil 1 5w30, Genuine Nissan oil filter.
2012 Acura TL 6 MT
73447 miles
out 3 and 1/2 quarts AMSOIL Signature Series 5w20 (purchased from Pablo) plus one quart mix of make up oil
in: Pennzoil Ultra Platinum 5w20 and Fram ultra filter
4475 miles since last oil change, mm was at minus five percent
2012 Toyota Camry LE I4
Miles: 72,000
Out: Pennzoil Ultra Platium 5w20, Toyota oil filter
12 months, 6000 miles, 0 oil added during oci.
In: Idemitsu 0w20, Genuine Toyota oil filter.
2013 Chevy Impala 3.6 LFX
152k miles
Supertech Dexos High Mileage 5W30, Pronto PO2500 filter
drain plug 18 ft lbs
2016 Mitsubishi Outlander Sport 2.4
27k miles
Castrol Magnatec 5W20 Syn, Napa Gold 1356
drain plug 29 ft lbs
2018 Subaru Forester XT 2.0 DIT
2500 miles
Out: Valvoline Modern Engine 5w30 (Unimpressive VOA, replaced factory fill @ 500 miles)
In: Pennzoil Platinum 5w30 (d1 g2 formula), Subaru blue filter
Fumoto F108N (with top mount oil filter this makes for about a 20 minute oil change)
2017 Sonata 2.4L GDi
Out: Royal Purple 5W-20
Out: Hyundai oil Filter
In: Mobil 1 5W-20
In: Hyundai Oil Filter
2013 Santa Fe 2.0Turbo GDi
Out: Pennzoil Platinum 5w30
Out: Hyundai Oil Filter
In: Mobil 1 5w30
New to me 2007 Ford escape 3.0
109,944 current miles
Out: Motorcraft 5w20 and a FL500S-Bulk oil
In: Motorcraft 5w30 and a FL500S-Bulk oil
Also did 2 drain and fills on the trans 3.2Q X2 of Motorcraft bulk MerconV.
All in i got 6Q of Motorcraft bulk 5w30 a FL500s and 7Q of bulk MerconV for $48. Not 2 bad.
2016 Mazda Axela 1.5l.
out:Castrol EDGE Extended Performance5w20.wix57002filter.for 5000kms.
in:total 9000future 0w20.remain the filter(JUST WANT TO HAVE A TRY FOR MORE 5000KMS).
Well,in china total 9000 costs 32rmb when it has a discount,while castrol edge costs at least 46rmb.BUT FOR MY MACHINE,Total works better.for instance,its quiet,speed up smoothly,and less fuel use.maybe cause of a lower 100℃ css at 8.1.
I may try Pennzoil Platinum 0w20 or Valvoline synpower next time.
2007 Chevy W/T classic 4.3 V6, 210,000 miles, 10,000 miles between oil changes.
out-Chevron Supreme 10/30, AC/Delco PF52 filter
in- Chevron Delo 10/30 2 quarts, Delo 15w40 3 quarts, AC/Delco PF52 filter.
(was going all Delo 15w40 but I wanted to use up some Delo 10/30 I had in an open gallon container)
2008 Toyota Sienna
Out: Mobil 1 Extended Performance 5w30
Fram Ultra
In: Mobil 1 Extended Performance 5w30
Fram Ultra
17,766 Miles
Blackstone oil report
TBN-2.2
Everthing was fine except Silicon which was at 30PPM. A little high, changed the air filter. Blackstone said to go to 19,000 miles on next oil change. Will sample again at that time.
1995 Mercedes E300d
Out:Amsoil AME 15w40 Diesel Oil
Mann Oil Filter
In: Amsoil AME 15w40 Diesel Oil
Mann Oil Fliter
14,978 Miles
Blackstone Oil Report
TBN-8.7
Lead-16
All other Elements were fine except this. They said to go 10,000 miles on next oil change and sample again. The lead's reading would likely be excess bearing wear. What would be the outcome if this were to continue? And, what would be my fix? Thank You, Bill PS, If it were not for this high lead reading I would go 25,000 to 30,000 miles on my oil changes on this car as my soot reading was only 0.2%!
