Post your latest oil change
It was seven months between changes and 8,700 miles.
2009 Sonata V6 Limited (which is the easiest oil change I've ever seen).
Mobil1 HM 5W-20 (Meijer sale + coupon = $21)
Puralator One filter
145,000 on the car now. Runs great! Looked under the valve cover and it's as clean as can be!
Originally Posted By: SR5
Originally Posted By: EricBeau
Not my personal vehicle ....
2016 Ford Fiesta SE- 22,
16,197 miles on oil and filter.
Out: Dealer bulk synthetic blend 5W-20 and Motorcraft FL910S
In: Dealer bulk synthetic blend 5W-20 and Motorcraft FL910S
Eeeek !!
I'd love to pull the rocker cover off of that!
2004 Toyota Solara se 2.4 2azfe
Out:
German Castrol 0W30 and a Bosch Distance+ D3421 from walmart clearance Looked ugly as [censored] when I cut it open, one of the endcaps fell off which really doesn't inspire confidence will post pick
In:
Valvoline Synpower Maxlife 5W30 and a Royal Purple 20-400 oversize.
Bosch was oversized too and the can didn't look worse for wear after ~4800 miles
2014 Ford Explorer Limited 3.5L TiVCT
OCI = 9,500 miles (6 months)
Out:
Mobil 1 AFE 0W-20 SN and FRAM Ultra XG10575
In:
Out:
In:
Due you plan to do a UOA on the AFE?
2015 Ford Escape 1.6l ecoboost
this is my parents vehicle that they bought last november with a little over 24,000 miles on it, it now had just under 27,000, so i don't know for sure when the oil was changed as i couldn't find an oil change decal
the oil service required message came up so i changed the oil and reset it, so we'll see when it comes on next
if it was dealer serviced i imagine it had Motorcraft 5w20 synblend in it and it had a MC 910-s filter on it.
Put the same size MC filter back on and filled it with 4.3 quarts of Pennzoil Platinum 5w20
2017 GMC 2500 6.0L @ 29,200 KM / 548 hrs.
Out 5w30 Dexos Penz & Penz filter from fast lube joint.
In 10W40 Duron CJ-4 & Delco filter. 7 liters if you let it drip out & parked up hill.
Is there a long filter option for this engine?
2012 Hyundai Elantra GLS, 1.8L
Out: Castrol GTX Magnatec 5W-30 .... FRAM Ultra Oil Filter #XG9688
In: Pennzoil Conventional (PYB) 5W-30 .... Hyundai OEM Oil Filter #26300-35504
-Changed PCV Valve
2001 Toyota Camry 4cyl
1,460 miles on oil and filter, 6 month OCI
Out: 4qts Valvoline MaxLife 5W-30 Synthetic Blend and FRAM TG4967
In: 4qts Valvoline MaxLife 5W-30 Synthetic Blend and FRAM PH4967 (build date of February 2nd, 2018, 1st shift; new style with silicone ADBV)
Planning on sticking to my 6 month OCI for this short-tripper. My commute is 1.3 miles one way. This car doesn’t see much else driving; roughly 300 miles per month.
Neglected 2003 Dodge Dakota 3.9 Liter V6. Lotsa hard miles.
Out - Maybe 3 quarts of oil shop bazillion mile sludge and filter. Black, thick and nasty.
In - 4 quarts Valvoline MaxLife Synthetic Blend 5w30 and Ecogard Synthetic filter.
Also, replaced NGK plugs (looked good) with OEM Champions.
What a difference! Hard to believe cheapo Champions made that much difference.
Gonna run it a maybe 500 miles and fill with MaxLife 10w30, as 10w30 is the recommended viscosity.
14 Lancer
51xxx
8 months oci/ 6xxx miles
Out : Redline 5w30. Purolator filter
In : 1/2 quart Pennzoil Platinum 10W30, 1 qt Red Line 10w30. 3 qts Amsoil 5W30. Purolator filter.
05' Grandis.
1 year, 10,000M.
Out- Unknown indy dealer serviced at purchase, blue-print filter. 1.5 litres top (keeping at top of dip stick).
In - M1 FS 0-40 (was on sale), Mann filter (cheaper than Bosch). 4.5 litres.
2012 Town and Country, 96,5xx miles, 4600 on oil.
Out Valvoline Durablend 10w30, with a bottle of Schaeffer Micron Moly add. SuperTech filter.
In, 4.5 quarts of 5w20 Mobil Super, 2.5 quarts of Mobil 1 15w50 Extended Performance.
The Widman calculator gives me an oil in the 10w30 range, and I'm using a few AZ clearance quarts of the M1 up. STP filter.
2004 Ford F-250 with 5.4 V8
Out: Motorcraft 5w20/Motorcraft Oil Filter
In: Carquest 5w20 Synthetic/Carquest Oil Filter
2011 Chrysler Town and Country
Out: Dealer Bulk/Unknown Filter
In: Mobil Super 5000 5W30/Mopar Oil Filter
1992 Chevrolet Cavalier RS, 2.2L
Out: Valvoline Conventional (VWB) 10W-30 .... ACDelco Classic Oil Filter PF47
In: Pennzoil Conventional (PYB) 10W-30 .... ACDelco Classic Oil Filter PF47
2001 Jeep Cherokee
Pennzoil Platinum Euro 0w40
Fram TG16
Other work done:
new champion plugs
New sway bar bushing and end links
Replaced radiator cap
Completely new rear drums
Fixed small radiator hose leak
