Post your latest oil change
Another one, a co-worker of mine.
2011 Nissan Rogue 113,560KMs
Out: Mystery Oil / Pegasus Filter
In: PYB 5W-30 / Napa ProSelect 21356
Napa ProSelect Air Filter
2015 GMC Terrain DENALI 3.6
In/Out
Pennz Platinum 5w30
Wix 57045 filter
FRAM air filter
14,957 miles.
Last week did the truck.
Out: MileSyn blend 5w30, MC 820s
In: Valvoline Maxlife blend 5w30, MC 820s
This weekend did the Corolla.
Out: ST Syn 5w20, Fram CH10358
In: MileSyn blend 5w30, Fram CH10358
Yesterday -
1st oil change on the Durango - 6214 miles - Oil life was still 20%
Out: Factory Fill
In: 6 quarts Valvoline Synpower 0w20 and OEM Mopar Filter
2007 Lexus ES 350 30k miles (!!) bought 8 months ago with only 17 k miles on it.
out: Mobile One EP 5W30, Mobile One filter, run 10k miles.... filter looked like brand new, no oil usage.
In: Mobile One EP 5W-30, Toyota filter, will run 10k miles again.
2007 4Runner v6 ~117k miles 5.3k oci
Out: chevron supreme 5w30 and Toyota filter
In: chevron supreme 5w30 and Toyota filter
Also had mechanic change out PCV valve. Consuming about .5 to .75 quarts per oci and hoping this can alleviate it. Old pcv had some crud on it but still rattled.
2008 Ford Ranger 3.0L, 68710 mi.
Out: 4.5 qts. ST 5w-20 FS, MC 400S, 3860 mi. OCI
In: 5 qts. Castrol Magnatec 5w-20, PL20195 (bigger filter)
I tried the Magnatec; so far not much difference. It may be a tiny bit quieter.
My trusty Nissan Altima 3.5
Out: Havoline Pro DS 5w30
In: Super S 5w30
Lady's Camry
Out: Castrol Magnatec 5w30
In : Lubrigold 5w30 2.5 qts
And 1 qt of Warren Oil SAE 30 grade
In: Super S 5w30
Lady's Camry
Nice work mate, I'm interested to know how that Lubrigold and SAE30 go, they are both from Warren I believe.
Yes sir they are both from Warren Oil. Car seems nice and quiet so far. It is still quite early like less than 250 miles. But I like it quite good so far. I thought that mixing in a thirty grade would be all right for summer time. Truth be told this mix would be just fine until early December. I can get these oils from gas stations and the price is fairly reasonable.
04 Cadillac CTS
Out: Mobil 1 5w30 w approx 8k miles and AC delco oil filter
In: smitty s 5w30 syn blend w AC delco oil filter
Will run smitty oil for 2k miles as a rinse
2015 Jeep Cherokee 3.2L V-6, odometer 43,135 miles
Out:5444 miles on PP 5w20, Wix WL10010, Shorter than usual OCI due to more short distance drives
In:QSAD 5w20 for the summer, Wix WL10010, plan to go 5k OCI
In the dealership getting new transmission installed under warranty currently, noticed the leak on the garage floor after backing the Jeep out of the garage while changing the oil last weekend. Leaking at the seam where the engine bolts to transmission.
2003 Chevrolet Silverado 1500, 5.3 V8, auto, 4WD
Out: Castrol GTX 5W-30, Fram Core filter
In: 6 QTS ACDelco conventional 10W-30, Napa Proselect 21042 filter
2005 Ford F-150, 5.4 V8, auto, 4WD
Out: unknown, Motorcraft FL-820S filter
In: 7 QTS ACDelco semi synthetic 5W-20, Napa Proselect 21372 filter
2003 Chevrolet Impala, 3.8 V6, auto
Out: first fill on rebuilt engine, ACDelco conventional 10W-30, Napa Proselect 21040 filter
In: 5 QTS ACDelco semi synthetic 5W-30, Napa Proselect 21040 filter
2008 Ford Focus, 2.0 4 cylinder, auto
Out: Valvoline conventional 5W-20, Service Champ filter
In: 5 QTS ACDelco semi synthetic 5W-20, Napa Proselect 21348 filter
2015 Chevrolet Silverado 1500, 5.3 V8, auto, 4WD
Out: ACDelco dexos semi synthetic 0W-20, ACDelco PF63E filter
In: 8 QTS ACDelco synthetic 5W-30 dexos, Napa Gold 7045 filter
2013 Ford Focus 2.0L Auto
Out: Motorcraft Synblend 5W-20, Motorcraft FL910S Filter
In: 5qt Valvoline Synpower, Motorcraft FL400S, also new Purolator air filter
2000 Chrysler Town and Country, 3.8 V6, auto
Out: unknown, Napa Proselect 21085 filter
In: 4 QTS Lubrigard 15W-40, 1 qt Lucas oil stabilizer, Napa Proselect 21085 filter
Wife's 2015 Dodge Journey Crossroads 3.6 Pentastar
41,709 miles
OCI: 7,619
Out: Valvoline SynPower 5w20 with NAPA Gold filter
In: NAPA Syn 5w20 with NAPA Gold filter
I collected the SynPower and will do the same when I drain the NAPA Syn in 7,619 miles. Planning on doing UOAs on both for a comparison.
