Post your latest oil change
2002 Ford Crown Victoria Police Interceptor 200,000 miles; 5250 miles and 4 months on this change. Change was done 4/25 but I forgot to post.
Out:
Valvoline Maxlife 5W20
Lubegard Bio-Tech engine oil treatment
Fram XG2 with 18,000 mi
In:
Valvoline Maxlife Syn 5W20, 5W30, and Synpower 20W50. Dont ask what ratio cause I don't know.
New Fram XG2
Probably keep up with 5-6k oil changes.
2009 Dodge Ram 2500 5.7 Hemi
Napa Conventional 5W30, Baldwin B329
Drain plug 25 ft lbs
1989 International Dump Truck
5 gallon bucket of Smittys SynBlend 15W40
Dual filter setup Napa Gold 1789
'02 Chevy Camaro, 260100 miles
Placed on perpetual OCI regimen since 247300 miles, until I run out of my stash of PU or can install a new engine.
Using ~1 qt per 1000 miles, so it gets a complete oil change every 5k miles.
Plan on changing the filter every 10k miles.
Out: Wix XP filter
In: Bosch Premium filter
Used 15 quarts in 13k miles
2009 Hyundai Sonata w/ 2.4L I4 (pre-GDI), 94800 miles
Out: Castrol GTX synblend mix of 5w20 and 5w30 after 7 months and 6300 miles
In: Castrol GTX synblend 5w20/5w30 mix and a little bit of Castrol EDGE Extended Performance 0w20 to top off
Using blue OEM filters. This fill is the last of this discontinued Castrol GTX synthetic blend oil purchased at AutoZone several years ago for $1/qt. on clearance. M1 will likely be next.
1992 Chevrolet Cavalier RS, 2.2L
Out: Valvoline conventional 5w30 .... ACDelco Classic Oil Filter PF47
In: Valvoline conventional 10w30 .... ACDelco Classic Oil Filter PF47
Severe Service
2017 Ford Expedition 3.5 Ecoboost..... 2450 miles
Out: Factory Fill
In: 6 quarts of Motorcraft 5w30 Syn Blend w/ Motorcraft Filter
Oil Life Monitor was at 73%
Out: Factory Fill
My partner has a 2013 1.2 3 cylinder VW Polo which has had dealer only servicing since new, currently 28k on the clock.
VW reccomends 10k/1yr intervals.
It's about half way between its last and next service and the oil didn't look too healthy so swapped it out.
Out... VW 5w30 504/507 oil. I suspect Quantum brand.
In.. ASDA own brand 5w40 502/505 fully synthetic oil.
2014 Ram 1500, 5.7L Hemi
Out: Pennzoil Ultra Platium 5w20 (4,000 miles on oil)
In: Pennzoil Ultra Platium 5w20 and OEM Filter
OLM was at 62%
2012 Acura TL 6 MT
out: 5W20 PU
in: 4 quarts Amsoil 5W20 Signature Series (purch'd from Pablo)
did not change Fram Ultra filter this time
MM was down to 5%.
Mileage 64378
Did not add any oil since previous change
A Friend's Car:
2012 KIA Forte, 2.0L
Out: Chevron Supreme Conventional 5W-20 .... FRAM Tough Guard TG9688
In: Chevron Supreme Conventional 5w30 .... WIX Oil Filter 51334
2015 Hyundai Sonata - 6,377 mile OCI - 59,175 miles on car. Collected oil for a used oil analysis.
Out: Pennzoil Ultra 5w30 & OEM filter
In: Mobil 1 Extended Performance 5w30 & OEM filter
Been a bit busy today working on one of my neighbour's tractors.
John Deere 5055E, 546 Hours.
Out: ? and John Deere RE519626
In: Napa Premium Lubricants (NPL) 15w40, RE519626
John Deere 6400, 5432 Hours.
Out: ? and Napa Gold 1243
In: NPL 15w40, John Deere T19044
Kubota M8030, 4910 Hours.
Out: ? and Kubota OEM
In: NPL 15w40, OEM
My 2015 chevy malibu: 27,980 current miles 15% left on the OLM
OUT: napa syn 0w20 and an acdelco ph64 filter.
IN: valvoline syn w/maxlife tech 0w20 and a acdelco ph64 filter.
Little over 6k on this oil change. Sending oil out to blacksone tomorrow.
99 VT
Out, Shell Helix Ultra 5w-40
In, Nulon Fast Flowing 10w-40 Fram Ultra filter.
Due to the [censored] heap dropping a bearing out of the blue. Only had a 1k or so kilometers on the oil change.
2011 Rav4 5-20 pennz
learned resource conserving encompasses energy conserving
the OEM $9 filter looks better as it doesn't have a plastic holder around it
