Post your latest oil change
Originally Posted By: chunt
2016 Nissan Altima 3.5. 2784 mile (6 month) OCI. 8284 miles on car.
out: Penz synthetic 5W30, FTG filter
in: M1 0W30, OEM filter
Any reason your OCI is under 3000.....while using a quality synthetic like PP. IMO, you could at least double the OCI mileage (6000) easily or go one year OCI's. Its a waste of quality oil and $$$.
2002 Subaru Outback H6 3.0 approx 111,500 miles
Out:
Pennzoil Platinum High Mileage 5w30 with NAPA Gold filter. 7000Ish miles, changed early due to worsening oil cooler gasket leak needing repair. Was down a quart and decided to repair and OCI rather than top up again.
In:
Castrol GTX High Mileage 5w30 with Purolater PureONE filter.
It's a 16, probably a warranty deal.
Warranty, Nissan says 6 months or 5000 miles. I use synthetic because I can get it almost as cheap as conventional due to the special sales.
2012 GMC Canyon 3.7 Vortec
85,363 miles
Pennzoil Gold 5W30, Napa ProSelect 21522
drain plug 19 ft lbs
5k oci
2011 Chevy 1500 4.8 Vortec
129,647 miles
QSUD 5W30, Fram XG 10060
drain plug 18 ft lbs
5k oci
Old car, modern oil.
Originally Posted By: MobilinHyundia
2009 Sonata 2.4l 12000 OCI
Out: Toyota 0W20
In: QS 5W50 OEM oil filter
Quite a viscosity jump there. 5w50 is the juice of Zeus IMO. Initial impressions? Did you have an mpg hit? I used 5w50 Castrol after M1 0w30 once. Was pleasantly surprised as the car did not have an MPG hit and felt smooth, without any sluggishness from higher viscosity. Valvoline 5w40 MST made that car (2006 Pontiac Vibe AWD) feel like I was towing an 18-wheeler, and engine lost 4mpg across the board. So definitely did not expect the 5w50 to perform as good as it did.
2013 Dodge journey 2.4, first oil change on my moms "new to her" car. Had 54k miles a the the time of change.
Out: Unkown
In: Valvoline Synpower with maxlife 5w20, Fram tough guard
2007 Honda Accord EXL (friend's car)
150k on vehicle
About 5700 miles on oil, 10 months. OLM at 10%
Out: Mobil 1 EP 5w-20, Denso First Time Fit
In: QS Ultimate Durability 5w-20, Purolator Synthetic
WOW, that is a lot of miles. I'm impressed.
It's less impressive when you convert km to miles.
601,503km is 373,757 (american) miles. Or just 60,150 swedish miles.
[/quote]
[/quote]
Nonetheless, it's still impressive. Good show.
1999 Ford F-150, 4.6 V8, auto, RWD
Out: 50/50 mix Napa and Coastal semi synthetic 5W-30, Napa Proselect 27502 filter
In: 5 QTS Napa 30wt, 1 quart Lucas oil stabilizer, Napa Proselect 21372 filter
Originally Posted By: fujirio
1998 corolla
157,000 miles
Mobil super 5000 5w-30
OCI: 3000 miles (please tell me if thats way to low)
I think you should stick with what you are doing. Keeping an older car with higher miles is nice, but if you have an older car with higher miles and it doesn't burn oil = you must be doing something right.
If you try extending it or putting additives or constantly changing things up and around you might give it an opportunity to burn oil. Then you would have ruined a beautiful thing.
1998 corolla
157,000 miles
I would change it every 6 months or 5000 miles which ever comes first.
