Post your latest oil change
2010 Ford Edge 3.5 Duratec
Mileage: 22980
Out: Napa Conventional 5w20 / Napa Pro-select Filter
In: Castrol GTX Magnatec Synthetic 5w20 / Motorcraft FL500S
3k on last OCI
This OCI will be 5k
96 Crown Victoria
316,670 miles on car
In: Shield Choice 5w30
Out: Trop Artic 5w30
Motorcraft FL-820S oil filter
08 Chevy Malibu LTZ 3.6
Out, Pennzoil Platinum 5w30
Wix 57045
In, Pennzoil Platinum 5w30
Wix 57045
53,296 miles
Originally Posted By: SatinSilver
Good choice Adam! The Magnatech might even quiet it down a bit. Report back if it does.
It definitely made a difference. Luckily I scored about 20qts at my local AutoZone. Also scored a ton, 38 qts RP 0w20 as well. I've noticed a big difference during idle and cold startup with the Magnatec during the 80 miles I drove today.
Car: GM / Holden / Opel Astra (AH)
OCI: 6 months / 8,000KM / 5,000 miles
Out: Castrol Magnatec 10W30 semi-synthetic (SN, A3/B4) + Wesfil-Cooper filter
In: Valvoline SynPower 0W40 full synthetic (SN, A3/B4, OEM's) + Valvoline synthetic blend media filter
2014 Kia Picanto 1.0 3 cylinder petrol engine.
28700 miles
Kia Oil Filter (Mann Hummel) replaced with OE Spec Mann Filter (Made in Korea)
Castrol Magnatec 5w30 A5/B5 SN out (in use approx 10k miles)
Shell Helix Ultra Professional AF Engine Oil 5W-20 SN A1/B1
Engine is now filled with the Kia specified oil viscosity as per Kia UK Website.
Engine seems to crank very slightly quicker on cold start and doesn't feel like it want to stall when ohllung away meaning you can slip the clutch a little less.
I didn't expect to notice any difference but I suppose with such a small low powered engine every little helps.
Will report back on any Economy improvements that might result.
Originally Posted By: bigjl
Engine seems to crank very slightly quicker on cold start and doesn't feel like it want to stall when pulling away, meaning you can slip the clutch a little less.
Yep, I hear you. Those small engines ...
2003 Ford Taurus 3.0L Vulcan
58,750 miles
out: Pennzoil Platinum 5w20 and Fram Ultra
in: Castrol GTX HM 5w20 and Motorcraft FL-400s
Starting to see oil weeps. Not many miles on car but it is 14 years old.
Also drained / refilled radiator with Zerex G-05. 8 quarts came out.
Rotated tires.
My 2003 ford taurus ses 146,871
Out: pennzoil gold 5w30 only 150 miles on oil
In: Pennzoil High Mileage 5w30 and kept the ST3600 on.
Did an oil change on it last week and started getting drips. So i switched to a High Mileage oil.
The older 1.1 Picanto (2005) is also specced for 5w20 in the Kia oil spec table I downloaded from the Kia UK Website.
I stuck with 5w30 as I was concerned about oil consumption due to the cars High miles (now 142k). I haven't had to top up the oil whatsoever.
The older model is specced for 5w20 SL, the newer one 5w20 SM but I could only get hold of 5w20 SN.
Not that clued up on API specs, but think Inwill put the same oil in to the older one.
It's a throwaway car anyway.
58,750 miles
Rotated tires.
I consider rotating the tyres on the 14 Picanto when I did the oil and filter change. But didn't bother as the fronts are almost new, the OE Hankooks had worn quickly on the front and also worn on the edge, still nearly 3mm of thread in the centre but closer to 2mm on the edge and with Winter coming I just put on New at the front.
I really need to remember to rotate my tyres.
I thinkn2 years with the X351 XJL and the wider rears has broken my habit.
2001 Lexus ES300. 218K miles.
Out: 1 Gallon Delo SD 15w30 + 1 quart Havoline synthetic 5w-20 w/ 2900 miles
In: 2:3 mix of Quaker State Ultimate Durability 10w30 (manufactured June 2016) and Pennzoil Ultra 0w-40 (from December 2013).
This is five of the 13 Autozone clearance SOPUS quarts I got in 2016 for (almost) free after rebate.
Left the oil filter alone, TG8316 with 2900 miles.
I warmed the PU bottles up last night with hot water and shook them vigorously. Looked in all three bottles after pouring today and found none of the "additive fallout" that I've seen reported by some folks. Next time I dip into the PU stash, I'll see how it fares without shaking etc...
2015 GMC Terrain DENALI 3.6
Out. Pennzoil Platinum 5w30
In. Pennzoil Platinum 5w30
Wix 57045
10,941 miles
2011 Chevy 1500 4.8 Vortec 125,871 miles
Out:Supertech Dexos 5W30 Baldwin B160 5,571 mi
In:Quaker State Ultimate Durability 5W30 Royal Purple 10-48 filter
Drain plug 18 ft lbs
6k oci with Quaker State Ultimate Durability and RP filter
1995 Lexus Sc300 (the V6 has a bigger sump than the V8)
Out 5 FULL quarts (well I might have been up to a quart low) of Pennzoil Platinum (should be called GOLD) 10w30 with a Mobil 1 filter.
In: 5 FULL quarts of Quaker State ULTIMATE DURABILITY 10w30 with a Fram Ultra filter.
