Post your latest oil change
2007 Hyundai Santa Fe 3.3L 170K
Out: 5qts Valvoline Maxlife 5w30 and .5qts PHM Fram CH9999
In: 5.5 qts Valvoline Maxlife Fram XG9999 (first run)
Around 5,400 mile OCI
Wife's 2011 Ford Mustang 3.7L V6
4.8K miles / 1 year on oil, 39K total on vehicle
Out : 6 qts. Mobil 1 5W-20 and a Mobil 1 M1-212 filter
In: 6 qts. QSUD 5W-20 and a Mobil 1 M1-212 filter
2012 Kia Sorento 3.5 v6. 99k miles
Out: 6 quarts 5w20 Mobil Super Syn, Our Classic Cartridge filter
In: 5 quarts M1 5w20 High Mileage, 1 quart Mobil Super Syn 5w20. Wix Cartridge Filter
7500 mile OCIs
2013 Cruze turbo
Out Mobil 1 5w30
In Mobil 1 10w30
AC Delco (Hengst) filters
6500 mile OCI (73k on the clock)
Nissan Versa Note 2014 300005 miles. Changing on Nissans severe use schedule. I change before the 3750 mile suggestion so this fell on pretty much even 30000. 3000 miles x 10 oil changes. Keeps the math simpler. With the Versa having low capacity oil sump I am not a big fan of leaving just over 3 quarts in for much longer. It is getting pretty dark looking right around 2800 miles. That little 1.6 liter engine works hard. I want to keep oil fresh in it.
Out Pennzoil Premium 5w30 with Purolator filter. Had a stash of those filters and then they developed their questionable reputation. Figure low OCI will be fine. Decided Premium was over kill for such short OCI so...
In Pennzoil Gold 5w30 and Microgard filter. After getting rid of Purolator stash I will be using Microgard or ST filters for this car due to really short OCI.
Owners manual says car takes 3.75 quarts of oil. I measured perfect amount to dump in. Wow, I still put in to much. Had to crawl under and remove drain plug to get out a bit of oil. Next time I will put in 3.25 quarts and check it like I had been doing it.
Just changed my Cruze turbo - it only holds 4.2 - and ran it 6500 miles on Mobil 1 bought on sale ...
(18% on OLM) ...
Doubt that cost anymore - or was any less in terms of protection ...
2007 Sonata 2.4L 132,489 miles ... OEM Hyundai filter part num 26300-35503 and M1 0w20 EP oil. First time ever using a 20 weight. It just felt wrong.
2011 Ford Taurus sel 3.5L V6
Out: QSAD 5W20 and MC FL500s
In: Pennzoil Platinum (pure plus) 5W20 and K&N HP-2011 filter
I had no plans to buy a $12.58 oil filter but I went into my little walmart late at night and couldn't find the usual FL500S. They were also out of all versions of the Fram 10575. There was one K&N (for my application) on the shelf so I grabbed that. It felt heavier before use than the FL500 feels loaded with oil. I found a thread where Jim Allen said the K&N's efficiency is somewhere between the basic filters and the top of the line filters. Not the best, but reasonable I guess.
Since I tried a new filter, I decided to see what the Pennzoil Platinum was all about, too. My engine has never used any oil but I'm curious to see if the Platinum drops on the stick as others have noted when first trying it out.
2013 Mazda 3 Skyactiv, 57K
Out: Pennzoil Platinum 0W20, Mazda Filter, about 9k.
In: Mobil 1 AFE 0W20, Wix 57002 Filter
The oil that drained out was very, very nasty.
2006 Lincoln LS, 74640 miles
out Pennzoil Plat, 5W-30, 4180 miles, NAPA Gold #7302 filter
in Quaker State Ult Dur, 5W-30, Purolator Pure One # PL15317
Drain oil somewhat translucent, but glitter in sun?
6 quarts mid range on stick
2012 bmw x5 3lit turbo
8000 on m1 0w40
77800 on vehicle
Been doing 7500 to 8000 mile changes
Olm would kick in at 16000 to 18000 with the driving my wife does
I changed oil this morning.
2007 Ford Focus with 10k OCIs, with 160K on the Unit. No oil loss in OCI.
Old oil out: M1 0-20 AFE
New oil in: M1 0-20 AFE
Oil Filter: MC FL 910 old and new
IMO....you are under-utilizing PP at only 4180 miles. That oil should go at least 7500 mile and even more.
QSUD is another excellent syn which I'm using now, and should be able to do 7500 easy.
Also, you might consider using a top-shelf filter like a Fram Ultra (2x7500) or Fram Tough Guard, to get top-notch filtration.
2010 Chrysler Sebring Touring with 2.4L engine. Out with Penn. Platinum 5w20, and in with fresh Platinum 5w20. Left the Fram Ultra filter on this change. Changed it at 6982.4 miles, and it dropped just about a half quart of oil. I forget the total mileage, but it's just a little over 140k now.
L8R,
Matt
2002 Nissan Xterra 3.3L V6. Drained out 76 semi-syn 5w30 oil with a STP filter and put in Kendall synthetic ($2.99 a qt!) and a Bosch filter. Ran the oil for 3,300 miles.
2013 Escape 1.6 Ecoboost
PYB 5W20 Napa Gold 1348
Drain plug torqued to 21 ft lbs
5k oci 30k miles
2007 Dodge Ram 3500 5.9 Cummins
mobil Delvac 15W40 Fram XG3976A
Drain plug torqued to 37 ft lbs
5k oci 133,312 miles
