Post your latest oil change
2002 Chevy Trailblazer LTZ 4.2L 111,458 miles. 5,940 miles on this OCI (1 year) and the OLM was at 33%. Fram Ultra came off after 2 years and 11,000 miles
Out: Castrol SynBlend 5w30 & Fram Ultra
In: Pennzoil Platinum HM 5w30 & Fram Ultra
2010 Dodge Ram 3500 6.7L Cummins
15173KM on this run. Took a sample for UOA. Installed oil drain valve for easy sampling.
Out: Rotella T6 5W-40 + 1 Can Liqui Moly Anti Friction
Fleetguard LF16035
In: Rotella T6 5W-40 + 1 Can Liqui Moly Anti Friction
Donaldson DBL7349
Skoda Octavia 1.9 TDI PD, 260k kilometers
out: Teboil Diamond Diesel 5W40 (505.01 rated) and Hengst filter
in: Castrol Edge Turbo Diesel 5W40 (505.01 rated) and Mann HU719/7x filter
2008 Hyundai Sonata 4cyl
Out: Kendall GT1 syn-blend uknown filter
In: Mobil Super dyno 10w30, purolator filter
Firt time using Mobil on this car and the engine is making less noise and running quiter. I've used Valvoline conventional, Castrol GTX and Kendall in the past OCIs and never got such amazing results with the Mobil Super 5000.
2013 Jeep Wrangler 3.6
Out: Pennzoil Ultra Platinum 5w-20 and Mopar cartridge filter.
In: Same
2014 Hyundai Elantra Coupe 2.0
Out: Pennzoil Ultra Platinum 0w-40 and Hyundai OEM Filter
In: Same
2016 Ram 2500 Laramie Long Horn 6.4L 4x4 4:10 gears, changed out the filter from Mopar at 1500 miles to wix XP, change factory oil out and filter at 3000 mile to Amsoil 0-40 signaturee and Amsoil Ea filter. Have 9000 on the clock now and will be sending a sample to Blackstone labs and put Amsoil back in.
02 Grand Caravan
Out: Pennzoil Conventional and Fram Ultra
In: Pennzoil Platinum 5w30 and Fram Ultra
First time going Full Synthetic on the van, can't wait to see how it goes.
yesterday
2005 Dodge Ram 2500 5.9 Cummins, 324,200 miles
out : Mobil Delvac 15W40, Napa Gold 7620
in: same
Oil and filter changed every 7k, been dong this oci with the same oil and filter for the last 100k miles,
drain plug torqued to 37 ft lbs
In: 50/50 Mobil 1 10w30/Mobil 1 10w30 HM
Out: Pennzoil Platinum 5w30
Filter for both Mobil 1 M212
Change trans spin on PureOne off for Wix XP on
1 qt TransMax Syn ATF
GMC Canyon below
1992 Chevy Suburban 7.4L Big Block
Out: 7 qts Mobil 1 10w30, AC Delco Prof Filter on 8-12-16
In: 7 qts Mobil 1 0W-40, no filter change
Miles on vehicle: 57,027
Miles on oil: 1,781 (last at 55,246)
Time on oil: 60 months
Make up oil added: less than 1/2 qt
- 90% short trip, a few long 500 round mile trips, 99% of it's life in the garage, didn't change the filter because of low miles, we'll see what it looks like in another 5 years - getting UOA on the 5 yr old M1
link to UOA - https://bobistheoilguy.com/forums/ubbthreads.php/topics/4190879/1992_Surburban_Big_Block_-_M1_
2011 Dmax LML 103K Km, 1608 hours.
out; SAE40 CF2
in; Castrol GTX 10W40, on 1/2 price & free Fram 9100 filters with 5 liter bottle.
With truck parked up-hill & overnight drip, it took 12 liters to fill.
2007 Saturn Relay w/3.9L. 118K miles. 5K OCI (OLM down to 1%)
Out: Castrol GTX w/Carquest Red filter (Used car dealer threw in the oil change from a reputable local shop when wife purchased vehicle so I trusted it)
In: Napa Syn 5w30 w/Wix 51522
1987 4Runner 22RE 5SP currently just shy of 316,000 miles
Out: Super Tech 5w30 CarQuest Blue 85515
In: Liqui Moly 10w40 MoS2 Purolator Boss 10241
UOA for the ST is posted
2004 Lexus ES330 3MZFE 5AT Currently just over 144,000 miles
Out: Valvoline SynPower 5w30 Motorcraft FL910S
In: 4 quarts Mobil 1 5w30 SM spec 1 quart Redline 5w30 Motorcraft FL910S
UOA for SynPower is posted as well
2010 Nissan Altima Coupe 2.5 109k miles
Supertech Dexos 5W30, Fram XG6607
new washer on plug, torqued to 25 ft lbs
car is short tripped so I set the maintenance minder to go off at 4000 miles
2010 Altima 3.5L V6, 36k
Out: Mobil 1 Extended Performance 5w30, Fram XG6607 Filter, 3700 miles (1 year)
In: Mobil 1 Extended Performance 5w30, Fram FPS7317 Filter
I also flushed the brake fluid during this service.
2000 Toyota 4Runner 5vz-fe
Out: OEM YZZD3 (oversized), 4qts Rotella T5 10w30/2qts Rotella T6 5w40
In: OEM YZZD3, 6qts Valvoline Maxlife Synthetic 5w30.
Hoping to stem a small seepage between my block and oil pump... Seems like the highest rated High Mileage oil.
