Post your latest oil change
Originally Posted By: 901Memphis
Also at the end of the drain on the old oil I ran first a quart of DexronVI through with the drain plug open and also a quart of Mobil 1 Turbo Diesel Truck 5w40 I got for $1
Did this get anything out?
2013 Subaru Forester XT with 35050 miles
Drained Mobil 1 5W30 with about 4650 miles, removed blue Subie oil filter
Filled with Mobil 1 5W30 and a smidgen of Quaker State Ultimate Durability 5W30 to top off, used NAPA Gold 7055 filter (same as Wix 57055 which I have found for about $2 cheaper at O'Reilly's)
2008 Hyundai Accent
Hyundai filter
out 3 qts Mobil 1 Extended Performance 0w20
in 3.5 qts Mobil 1 Extended Performance 0w20
9995 miles
added one qt Mobil 1 Extended Performance 0w20 and was 1/2 qt down when changed.
I thought the EP oil slowed down the consumption but it did not. Over the 9995m it used 1.5 qts of oil. Before with the Mobil 1 Advanced Fuel Economy 0w20 and 7500m oci it used one qt.
Yes I got some larger copper flakes out that must have been sitting for some time.
I really want to do a idle flush with some cheap dino, but not sure how much I'm comfortable with wasting time do this. I'm estimating 3 quarts of fresh oil while idling should be sufficient since it's a 4.5 quart system capacity and I would be leaving the filter on during such a flush. I don't think I'd like to risk it with only 2 quarts but I'm betting it would be fine.
I also took a sample for a used oil analysis I'm tracking high lead/copper wear, but since my wifes been driving it I don't see any fine copper glitter in the drain anymore...I'm starting to believe my driving style is to blame for the high wear.
1967 VW Beetle
OUT: 3.5 qts. Delo 15w30, approx. 1920 miles
IN: 4 qts. Mag1 5w40 All-Fleet
FL400s filter not changed.
I drained the oil to change the sump plate gasket due to a significant leak. Decided to just put in new oil and use up the remaining gallon of Mag1 I had.
The Delo was horrible looking, very black and cruddy. I'll do a used oil analysis if I can scrape up $16.00 for a kit from NAPA.
2008 Crown Vic P71 with 120,450 miles.
Out: Napa Semi-Synthetic 5W-20 and Napa Proline filter
In: Pennzoil Ultra Platinum 5w30 and Wix filter.
Thank you, Pennzoil, for the free trial. Car's running quieter on your oil.
2015 Ford Focus ST
Out: Mix of Pennzoil Ultra Platium 5w30 and Euro Platinum 5W40 Fram Ultra Filter
In: 3qts Mobil 1 Extended Performance 5w30, 3qts Mobil 1 0W40 Amsoil EAO34
Parents 05 Ford explorer.
out Havoline 5w30 with microgard filter, i think there was some lucas in there as well.
In Microgard filter again with Valvoline Maxlife 5w30
Miniamikotaro
Hope you post that Beetle UOA! Looking forward to seeing it!
Weren't you singing the praises of Delo 15w30 a few months back?
1996 Ranger 4.0
out 5 quarts motorcraft 5w30 motorcraft filter
in 5 quarts smitty's superS 5w30 and partsmaster (wix) filter
About 1 year oci unknown mileage.
1994 Chevy C1500 5.7 208k miles
Out 5qts castrol gtx 5w30 + micro guard filter
In 5qts Pennzoil High Mileage 5w30 + wix filter
2011 Mazda 6 - 72k miles
Out 5qts Castrol Edge Syntec Black Bottle 0w-20 & Fram TG (10k miles)
In 5qts Castrol Edge Syntec with Titanium Black Bottle 0w20 & Fram TG
2010 Hyundai Genesis Coupe 2L turbo
3308 miles
Out 5 qts Mobil 1 Extended Performance 0w30 Wix 51335 filter
In 5 qts Mobil 1 Extended Performance 5w30 Wix 51335 filter
2008 toyota sienna 213,172 miles on van.
out,Mobil 1 Extended Performance 5w30, fram ultra oil filter.
in, Mobil 1 Extended Performance 5w30, fram oil filter.
12,744 miles on oil. No top off oil added during oil run.
sent in oil sample to blackstone lab.
tbn left in oil-2.4,They said to go 14,000-15,000 on next oil run. Also, there was less wear on engine at 12,744 than the universal average of 6,500 miles.Properties as follows,SUS Viscosity@ 210F 58.4/55-62,cst [email protected]/8.8-11.1 Flaspoint in F-405/>365 Fuel%0 Water% 0/0 Insolubles% 0.2/<0.6 Not a bad oil run!
1983 Mercedes 240D 4 speed manual 259,770 miles on car.
out, Shell Rotella 5w-40 Mann oil filter
in, Shell Rotella 5w-40 Mann oil filter
6110 miles on oil, 2 Quarts of make up oil added during oil run.
Sent in a sample to Blackstone labs.
TBN left in oil-9.3
They said the next oil run should be 8,000 miles.
This was due to wear levels at 6,110 miles were in line with the universal average of 3,300 mile oil run. Soot level was at 0.9. Mercedes says not to go over 2.0% so this was less than half of that. That being said 12,000 miles should be able to run. Not a bad oil run!
2009 Prius, 106k miles.
Out: Mobil 1 Extended Performance 5w30, OEM filter
In: 50/50 Mobil 1 Extended Performance 5w30/Mobil 1 High Mileage 5w30, OEM filter
