Post your latest oil change
2000 Century- Using up a few stragglers from the stash.
Out-Havoline 5W30 Synthetic. Mobil 1 filter.
In- Mobil 1 TDT 5W40, 3 qts. 1.5 qts. Havoline 5W30 Mobil 1 filter.
Oil change on 7/15/15
2006 Camry
74,307 miles
8,900-mile OCI (so almost 9,000 miles)
10 days shy of 1-year OCI
Out: Pennzoil Ultra 5w-30 and oversized M1-209 filter
In: Pennzoil Ultra 5w-30 and oversized M1-209 filter
Had considered doing a Blackstone Labs analysis on this 9,000-mile run but not worth $50 since the original Ultra has been discontinued, and I have just one jug left for next year. Wish they hadn't discontinued this excellent oil. What will I use in 2 years: Red Line? What other oils are comparable to the original Ultra? I guess I can always go back to Amsoil. If you want to continue this convo, please use my other thread about the oil tech using a wrong drain plug gasket.
Oil changed on 7/12/15
2010 Ford Fusion w/ 2.5L
200,057 miles
7,557 miles on the oil
Filter Out: Motorcraft FL400s filter
Oil Out: Blend of ~4qts VWB 10w30 and ~1.5qts Valvoline Next Gen 5w20
Filter In: Motorcraft FL400s filter
Oil In: Blend of ~1qt Rotella T5 10w30, 2qts Valvoline Next Gen 5w20, 2qts Castrol SynBlend 5w20, ~.5qt Valvoline Next Gen 5w30
2012 jeep liberty 3.7L 4500 mile oci (oil life monitor tripped on)
Out: qsad 5w-20 and a fram 10575 filter
In: qsad 5w-20 and a proline 22500 filter
1989 Chevy Suburban R1500 - 5.7 TBI V8
Parents old beater that they love - 350k miles plus on it -
OCI - 5,491 miles - 9 months
Out - Rotella T5 10W-30- 5qts and Purolator White Oil filter L34631 (will cut and post later this weekend)
In - Formula Shell 10W-30 - 5qts with Hastings Oil filter - LF279
2001 Ranger 2.3L, 103,500 miles.
Out: Valvoline Synpower 0w20 after 6500 miles on Wix filter. Was since Nov 2014.
In: Pennzoil Platinum 5w20. Wix filter.
2005 Toyota Tacoma 4.0L, 133,560 miles
5,400 mile OCI
OUT: 5.5 qts M1 HM 5w30 and Toyota Denso Filter
IN: 5.5 qts M1 HM 5w30 and Toyota Denso Filter
2008 Camry 3.5L V6, 62k miles
Out - Mobil bulk 5w30, mystery filter, 4500 miles
In - QS 5w30 conventional, OE Toyota filter
06 Mazda 3 189k miles
Out: Pennzoil Platinum 5w20 Fram Ultra (7500 mi OCI)
In: Quaker State UD Syn 5w20 Wix Filter
2009 Toyota Corolla 1.8L 149,300 miles
Out: 2.5 Qt PP 5W20 & 2 Qt QSUD 0W20/Fram TG10358 6800 miles & 6 weeks 1/2 qt make up during OCI
In: QSUD 0W20/Toyota 04152-YZZA6
2014 Subaru Outback 2.5i Premium 28,640 miles
Out: Castrol Edge 0W-20/Subaru 15208AA15A 6400 miles & 5 months No make up, still at full mark
In: PPPP 0W20/Subaru 15208AA15A
I had to change out both a little early. My oldest son is using the Corolla at his NASA internship in Cleveland and has returned several times to see his girlfriend, plus trips to his grandmother's house in NW Ohio. He's got four more weeks to go and at this pace he'd be near a 12,000 mile OCI.
Changed out the Subaru last weekend since my wife and daughter were going out to Nebraska to see friends and would have been over the 7,500 mile OCI by the time they returned.
1999 Chevy S10 Reg Cab - Auto - 2.2L 4cyl
174,950 miles on vehicle
OCI - 4,134 miles and 19 months
Out - Formula Shell 10W30 Conventional - 5 qts - and a Purolator PureOne PL10111 (beat it up taking it off - debating on cutting it open or not , will post if I do cut it open)
In - Pennzoil High Mileage 5W30 - 5qts with a Fram PH3387A
Also changed out the air filter
2004 Mazda RX8, 1.3L Renesis rotary, 6 speed, 98,000 miles
3.5 quarts of NAPA Synthetic 5W-30
Bosch 3300 Distance + filter
2 cycle oil in the fuel
2003 Ford Focus 2.0l SPI
In: M1 EP 5w-20 (used the M1 rebate in May)
In: Fram Ultra XG3600
Out: PP 5w-20
Out: M1-209
5,500 miles on oil. I changed it now for two reasons.
1: 2nd change after head replacement
2: Several lengthy upcoming trips, don't want to deal with oil changes for 10k or so.
Also changed the fuel filter. Replaced with Wix filter.
Well, out with the Wix filter. Not sure, maybe was a bad one. But the oil pressure (mechanical gauge) was fluctuating about 8 psi at high frequency, like it had the jitters, any rpm, idle or going down the road under load. I pulled the Wix and spun a Motorcraft FL400s and it seems fine now, but the cold start will really tell because with the Wix it seemed to smooth out some after it warmed up. Still, should not have been that way. Maybe will have to send the Wix in for analysis.
