Post your latest oil change
2006 Grand Marquis
Out - Mobil 1 HM & Wix. 8k on OCI
In - Castrol GTXHM & Wix. (Didn't want to waste my mobil 1 stash since this will probably be the last time I change it's oil).
1998 Lexus LS400
Out: PP 5w-30 and a Bosch Distance Plus D3330.
In: PP 5w-30 and a Denso filter.
OCI: 5889 miles
I cut open the old filter and when I went to pull the filter media "assembly" out of the can the top metal plate just came off. It wasn't glued on.
I'll post photos in the oil filter section after I let the filter drain of excess oil.
2014 Hyundai Accent GL:
3,750 miles / 6,000 km OCI
OUT: Motormaster Formula 1 5w-20 conventional (by Shell Oil) & Hyundai oil filter.
IN: 2qts. Motormaster Formula 1 5w-20/ 2qts. PYB 5w-20 & Hyundai oil filter
Oil sample sent to Blackstone and will be posted when results are in.
2012 Ford Fusion SEL, 2.5 I4, Auto
Out: Presumably Kendall Semi Syn(Grade Unknown), Firestone TF335 filter
In: 5 Qts. Havoline conventional 5W-20, 1/2 Qt. QSGB 20W-50, Pronto PO241 filter
2001 Mazda 626 / 2.5 V6 / ATX
OUT: Pennzoil YB 10w30 and Fram PH7317 Filter
IN: Castrol GTX 10w30 and Fram PH7317 Filter
Miles on oil: 6,850
Miles on Car: 161,375
This was the longest oil change interval I've ever had in my many years of driving and maintaining various cars. From visual inspection (for what that's worth) the Pennzoil seems to have held up fine. The car used about 1 qt over the interval.
2004 Mazda RX8
Out
NAPA Synthetic 5W-30
FRAM OCOD PH6607 (last one I'll ever use)
In
3.5+ quarts of NAPA Synthetic 5W-30
Bosch Distance Plus 3300
2008 Hyundai Accent
115445 miles
7500 OCI
3.5 qts M1 0w20 AFE out
added 1/2 qt at 5k miles
3.5 qts 0w20 M1 EP in
Hyundai filter
2011 Mazda6
63,495 miles
Out: Pennzoil Platinum 0w20 and Purolator PureOne - 9,022mile OCI
In: Castrol Edge 0w20 and Fram Tough Guard
1976 Plymouth PB100 Van, 225 Slant 6
~4000-5000 mi on oil, ?29,000 on engine (don't know how many times the odo has rolled around, at least 129,000)
OUT: 4qts Delo 5w40 + 1qt something else I had laying around + topped off with 15w40 Delo many times since then, PL14670
IN: 4qts Delo 5w40 + 1qt Rislone Engine Treatment (it's green!), PSL20195
2004 Toyota Camry, 2AZ-FE w/ 164000 miles
Out: Havoline High Mileage 5w-20, AAP3600
In: Havoline Deposit Shield 10W-30, Purolator L14477
2000 Jeep Cherokee 4.0L ~194500 on odometer (really in the 130s).
Out: PYB 5w/30(r), 10w-30 (1x), SAE30 (1x)
In: Pennzoil High Mileage 10w-30 (5x) / PYB 10w-30 (1x)
FL1A for both, of course.
'02 Accord, 138,999 miles car, 4865 miles oil.
In 12/13/14, out 4/8/15.
Out: G-Oil 5W-30, P1
In: G-Oil 5W-30, P1
We've put 20K on this car since buying it a year and a half ago.
It was my winter beater and remains my beater commuter.
Yeah, the engine sounded smoother and quieter with the fresh G-Oil.
I still have four jugs of FAR G-Oil remaining as well as a number of cheap after coupon code P1s.
Maybe the P1s will tear and have torn and maybe not.
1996 Toyota Avalon. 202,308 miles on 1MZ-FE engine.
Out:
Bosch Distance+ filter and winter witch's brew.
In:
1 quart Rislone, 4 quarts of Supertech 20W-50, 1 quart of Pennzoil 10W-30 & STP E-Core 3600 series filter.
2003 Ford Focus ZTS
151k on vehicle
Approx. 5k miles on bulk dino with a Parts Plus oil filter
Changed with Formula Shell 5W-20 and a Fram Extra Guard PH8316
