Post your latest oil change
2015 Toyota LC Prado
Out: Toyota Factory oil filter and Factory oil fill
In: Dealer 15W-40 (Dont know what oil it is, probably the cheapest Shell Dino Diesel Oil) abd Toyota 90915-YZZG1
Saturn SL2
Today @ 5359 miles, I added 7 ounces of Berrymans Chemtool B-12 to the oil and idled the engine for 20 minutes. I drained the oil and replaced with 3 quarts of Mobil Super 5w-30 and 12 ounces of MMO leaving the Fram filter in place.
I go for a 26 mile trip and dump the oil, DIRTY. After the oil is done draining, I sacrifice one more quart of Mobil Super 5w-30 flush out the pan a bit more. I put the drain plug back in place, put about 5 ounces of MMO in the sump and then proceed to remove the Fram PH3614 filter.
Despite what I was told about the MMO I used on the filter gasket when I installed it fusing it to the engine...I easily removed it without tools with my hand.
I then installed a fresh Motorcraft FL-_400S. Took the drain plug off to let the MMO drain out, plug back in. Wiped up the oil, added 1.5 quarts of Pennzoil Platinum 5w-20 & 2.5 quarts of Pennzoil Platinum 5w-30. I put the other .5 quart of PP 5w-20 in the 5w-30 jug. So I have 3 quarts for top-off, then I will do another oil change.
My Brothers 2014 Santa Fe 2.0T @aprox 11,000 kms. 2nd Oil change since new.
OUT: Total 5W30, Wix 51334
IN: Pennzoil Platinum 5W30, Wix 51334
2012 Jeep Patriot 39,015 miles
out: Quaker State 5w-20, Bosch filter 6000 miles
in: Havoline synthetic 5w-20, Bosch filter
2005 Ford Focus 153,213 miles
out: Havoline 5w-30, Microgard filter 5600 miles
in: Valvoline Synpower 5w-20, Wix filter
I will try to one oil from now on because for the first time the Focus needed 1 quart of m/u oil.
2013 Mazda 3 Skyactiv, 31.5k
Out - PP 0w-20, Bosch filter - 6k
In - PP 0w-20, Bosch Filter
2011 Toyota Prius, 101k
Out - Mobil 1 0w-20, Toyota Filter - 5k
In - 1 qt Mobil 1 0w-20, 3.5 qt QS Ultimate Durability 0w-20, Toyota Filter
TGMO 0w-20 and toyota OE filter on the sienna,
Kendall Synthetic blend and firestone filter on the accord.
One free the other quite inexpensive.
2000 SAAB 9-3, 139k
Out: M1 0W-40 & OEM filter
In: Castrol Edge 0W-40 & Bosch filter
My daily driver Audi 80
- out Shell Helix Ultra 5W-40 and Bosch filter
- in Shell Helix Ultra 5W-40 and Bosch filter
my dad's brand new Toyota Auris Tourer Sports 1.6 @1000 kilometers
- out factory fill and factory filter
- in TGMO 0W-20 and Toyota filter
2012 Ford F150 Eco-Boost
Out-Either 5w20 Valvoline or 5w30 Motorcraft Synthetic Blend depending on if I believe the sticker in the window or the grease monkey who did the change./Motorcraft FL500s Filter...1K
In-Castrol Edge/Fram TG10575
2009 Scion xD
Out-Mobil Super Synthetic 5w20/K&N PS-7021 5k
In-Pennzoil Platinum 5w20/K&N PS-7021
1/30/14
'09 Subaru Forester, about 3K and eleven months on oil, 67K car.
Out: Ultra 5W-30 and P1
In: Ultra 5W-30 and D+
1/31/14
'12 Honda Accord, about 7.8K oil,
Out: HGMO 0W-20, P1
In: TGMO 0W-20, K&N
2008 Honda Civic SI - 64250 miles
Out: Castrol Edge 0w30 GC + OEM S2000 oil filter
In: Pennzoil Platinum 5W30 w/ PPT + OEM S2000 oil filter
