Post your latest oil change
1984 Dodge Caravan, 2.6 Mitsubishi engine, 1 year since last change
Out -
(I think it might have been Mobil 5000 5w-30); Purolator L10193*
In - 3qts Rotella 10w-30, 1qt Castrol Titanium 10w-30, 1qt Defy 10w-30 (aka: whatever random stuff I had laying around); Purolator L10193
*I cut it apart. Pleats were wrinkled. ADBV still very soft. Filter area approx. 124 sq. in.
Out 5 qts Formula Shell 5W20 Motorcraft fl400s.
In 2 quarts Formula Shell synthetic and 2.5 quarts Formula Shell conventional. Both 5W20 and Motorcraft 910s.
2010 Ford Focus.
96 Saturn SC2
Out:
Ace Hardware 5W-30 and a Motorcraft FL-910S
In:
QSGB 5W-30 and a Motorcraft FL-400S
Will be rolling over 200K miles with this oil change.
2007 Accord coupe 73,000km
Out- M1 AFE 0w20/ Honda filter
In- Mazda Sn with moly 0w20/ Denso filter.
My car loves this new oil. Smoother, quieter, faster start and a noticeable increase in mpg!!!
2001 Saturn SL1, 1.9 SOHC
Out - 1 qt(!!!) whatever bulk oil Firestone uses, Firestone e-core filter
In - 5qts AAP store brand 5w-30, DW-241 filter
Hopefully, she'll actually check her oil this time around. I haven't opened the filter yet, hopefully it won't have the square hole.
2003 Toyota Corolla:
-Schaeffer 9000 5w40 +1/4 qt 5w30
-1/2 can Mos2
-Fram XG4967 filter
116,920 miles. Installed the Gold magnetic plug as well.
Was going to use some of my Amsoil OE stash but noticed two of the Schaeffer bottles were leaking so I used that. Never used a 40 weight in this car.
On the Focus today:
Out: Havoline conv 5w20, Pennzoil filter.
Time in service: 6 months/~4600 miles.
In: Havoline conv 5w20, Microgard filter (the older Fram/Honeywell clone).
I also did a transmission drain/fill with Valvoline MaxLife. The fluid looks brand spanking new now!
My Cousin's 2002 Saturn SL1 w/135,640 miles. 5,000 on the oil.
Amsoil Power Foam in the PCV hose, cleaned the PCV Valve & did an Amsoil Engine Flush for 15 minutes, then:
Out: Pennzoil Platinum 5w-30 + Ext. Length NAPA Gold
In: Pennzoil Platinum 5w-30 + Ext. Length NAPA Gold
