Post your latest oil change
changed my mom’s 2010 Santa Fe
Out: shop bulk and shop filter
In: Supertech 5w30 and Fram Filter
'25 KIA Soul LX ( Gravity Gray ) : 3rd Oil / Filter Change : Miles / Time on oil : 2,894 miles ( Miles : 4,647 - 7541 ) / Time : 5/26 > 9/20/25
OUT/OFF : PENNZOIL Ultra Platinum ( S.P.,GF-6A ) 0w-20 / HYUNDAI / KIA (O.E.M. ) 26300-35505 oil filter
IN/ON : Same
2012 GMC Canyon Vortec 2900
79.6k mi on vehicle
2980mi on oil
Hunting down an si intrusion so doing 2-3k OCI’s & sending in UOA to verify the air inlet system has been fixed. Also had my son do everything as this will be his vehicle by next month.
Out: Delo 400xsp 5W-40 & Napa Gold filter (gold filter had been in the bed toolbox for several years.)
In: Delo 400xsp 5W-40 & Amsoil filter
2018 VW Golf Sportwagen. 118,071 mi odo. 9,657 mile OCI. 3x track days on this fill with those hours (~4?) at ~270 deg F. 7x autocross, high RPM but only for less than 1 min per run, not enough to raise the temp much. Some consumption (~1 qt, seems to be about 1/4 qt/track day with minor amounts for auto crosses).
Out: 6 qts HPL Euro 5W40 + Mann filter.
In: 6 qts HPL Euro 5W40 + Mann filter.
Also changed the plugs (11,651 miles, I do them once per year) and fixed a coil pack hold-down, they strip easily so repaired with a Helicoil.
Samples sent to Blackstone/HPL. Info on my car/oil stuff here:
2018 Tacoma 3.5L TRD-Sport.
44.4k mi on the truck.
2.5k mi on the oil.
OUT: Dealership bulk 0w-20. The service receipts claim TGMO.
OFF: Whatever filter they use.
IN: Pennzoil Platinum 0w20 SN+. Two unopened 5-qt bottles have been sitting on the shelf in my shop for 6 years. 2019 copyright date.
ON: Fram Ultra XG9972. Has been sittting on shelf for 7 years. 2017 copyright date.
My shop is unheated, but the oil and filter looked fine. I immediately towed a 750 lbs, 5'x10' equipment trailer 320 mi round-trip after changing the oil, picking up 2500 lbs of lime at the halfway point. The engine didn't grenade on me, so I'm sure all is well. I also did both differentials and the transfer case at the same time.
This truck has mostly been dealership serviced since I bought it new. I did a single oil change at 5k mi without a filter swap, and the rear differential at 7k mi. The extended warranty just expired, so I figured I would start handling everything myself. The plan is to go ahead and change all fluids and filters now that the truck is 7 years old and close to 50k mi. I don't normally change my oil at 2.5k mi. I'm more of a 5 or 6k OCI kind of guy.
Here are some pics. I didn't think about taking a picture of the actual filter until it was already in the housing. I didn't want to pull it out and risk dirt intrusion.
EDIT -- Fixed photo orientation
Our '02 Grand Cherokee, 185k and counting:
Out - whatever frankenbrew was left in the sump and a twice-run XG16. Like most high mileage 4.7's, ours eats oil so I just keep it topped up with whatever I have lying around.
In - 4 quarts of Super Tech 5w-30 syn, a quart of Super Tech 10w-30 HM syn, topped up to level with a quart or so of leftover Valvoline Restore and Protect 5w-30. Threw on the K&N Silver I had sitting on the shelf from one of my RA orders, should be plenty good for the annual 5k OCI's this thing gets.
Nice. Loving carbon fiber air inlet too 😍😍
09 Prius, 229K
Out - Valvoline Restore and Protect 5W-30, Puro Boss filter
In - Valvoline Restore and Protect 5W-30, STP XL(Premium Guard).
Any chance of getting a photo of the oil fill hole to see the cleaning progress? And doe this engine use oil? Thanks for posting
Wow! Now that shows your confidence in HPL, an I bet your UOA will back you up! And those plugs look good! Only 11k on them?
Wow! Now that shows your confidence in HPL, an I bet your used oil analysis will back you up! And those plugs look good! Only 11k on them?
I *hope* my used oil analysis and the test HPL is doing well back me up 🤣. If not, I'll just go back to a more typical 5K/twice a year change...no biggie I'm sure I didn't ruin my engine.
Plugs on these "tuned to the moon" VWs need to be changed regularly and I just have decided since I get them for free with the FCP Euro Lifetime Replacement Guarantee, why not be safe and go once/year/12K or so. These are high-performance 2x colder heat range and non-projected tips, gap is 0.020".
2014 Accord coupe V6 manual at 30k Miles
5620 miles since last chsnge
Oil minder at 20%
Out: Pennzoil Ultra Platium 5w30/Fram Ultra filter
In: Valvoline Restore and Protect 0W20/Microgard Select filter
Burned about 1 quart on this OCI (no leak). Hoping Valvoline Restore and Protect can improve it. Went with 0W20 because the car seemed a hair sluggish with the thicker PUP but could be placebo.
I’ll keep a close eye on the dipstick to trace color and oil loss. I’m guessing my issue is minor enough that I can do a 5K OCI without overloading the filter.
Also topped off my battery with the Costco thingamajig. No idea if it really did anything the light was only on for about 15 minutes.
