Yes. Guess I'm just showing the typical bent pleats that come out of these housings.I hope that is the old oil filter you have in the picture..
Copy..Yes. Guess I'm just showing the typical bent pleats that come out of these housings.
Great work and pics my friend. Thank YouMy 2012 3.7 F150 with 280k miles
Both Pentius PLXL 10575 filters
Pic on the left has 5k on it and was used with Castrol EDGE Extended Performance 5w30. No wavy pleats/tears and ADBV was perfect
Middle and right pic that filter has 7,376 miles on it and was used with Castrol Euro 5w30 api SL
Filter media and ADBV were again perfect.
Im definitely impressed with the China/Vietnam/Korea made filters.
Ill be using them from here on out. Just spun on my last Pentius 10575 last night along with some Castrol Euro 5W30, Ill cut that one in 7k
Got my filter cutter on Amazon for $20, identical to Longacre and works great
I have and a few said it made zero difference.If you had been paying attention to the many testimonials of members in here then you would know that this oil is not just hype, it’s the real deal and it works in almost every case. Some results show more improvement in consumption than others but almost everyone reports some sort of improvement, myself included (it reduced my Civic’s consumption by about 50%)
Well those are the rare ones. A huge majority of people here have seen favorable results. Sounds to me like you have an axe to grind against Valvoline and are only seeing the bad results and are completely ignoring the good ones. But you do youI have and a few said it made zero difference.
