- Joined
- Nov 20, 2021
- Messages
- 2,210
It's what was on the work order, the car is being flipped for resale, and it doesn't require a synthetic.May I ask why conventional, if you don't mind?![]()
didnt ford was recommending the bottle and glass on the right per oc.2022 F150 3.5 PowerBoost 17,700 miles.
Only a 2,500 mile OCI, have a trip coming up so changed early. Had a weeeee nip too.
Out: ST Synthetic 5w30; MP10575
In: Mobil 1 0w30 AFE; MP10575
If you’ve ever tried to change the filter on a Powerboost… It should come with complimentary liquor.didnt ford was recommending the bottle and glass on the right per oc.
Id prefer a steak dinner and spa day as well.If you’ve ever tried to change the filter on a Powerboost… It should come with complimentary liquor.
Good choice! Jeffersons is top notch.2022 F150 3.5 PowerBoost 17,700 miles.
Any thoughts of moving up to a 0w12 eventually?2022 Toyota Corolla Cross.
119,841 vehicle miles.
In n out.
High Performance Lubricants,
Premium Plus.
0W8.
30,634 OCI.
Mobil 1 M-103A Extended Performance oil filter.
30,634 FCI.
I continue to be amazed by this company known as
High Performance Lubricants.
Move up ? You thick oil guysAny thoughts of moving up to a 0w12 eventually?
How much top-off oil was needed during that 30.6k OCI?
A VOA or UOA on 0w8 HPL would be interesting to read.
If you search my threads, you will see the data.Any thoughts of moving up to a 0w12 eventually?
have you updated the valve cover to the new PCV? gm had a TSB out for it back in the day.2005 Suburban 5.3
234k on the clock
OUT: 6 pts Mobil 1 Extended Performance 5W-30 (2022), WIX 51522 filter
IN: Rotella Gas Truck 5W-30 (2018+2019), WIX 51522 filter
4,363 miles on the OCI. Thinking on subbing out (or if it consumes) 1 qt of the HPL EC for the last 1-2k of the OCI. Should be changing next around 239k.
