Post Your Latest (Motorcycle) Oil Change!
2014 Triumph tiger 800xc and 2012 Honda NC700X
Flushed new brake fluid in through the rear brakes
Usually flushed every 2-3 years
Tiger:
out - prestone dot 4
in - supertech dot 4
quantity flushed: roughly 60ml
Honda:
out - unknown, presumably honda dealer fluid (PO had the bike serviced prior to selling in 2018)
Didn't take much to get rid of the cloudy/dark fluid and start flowing clear fluid. I would say that for each bike, by the time i flushed roughly 30ml through, the fluid started coming out clear through the tube. I thought I would have to use 100ml for each brake, but I believe that's overkill. 60ml is more than enough.
Motormaster semi-synthetic diesel (Rotella T5) 10w30 for the gearbox of my 1979 Yamaha RD400 (2 stroke). i have been using this oil for couple years, very cheap and I change it often.
Wanted to go 6,000 miles on the ZRX1200 before changing the current Mobil 1 10w40 4T. Got to 5,345 miles and decided to change oil and filter tonight after a nice evening ride. I change the filter every other oil change, this was the second run so it was changed.
Went with the same oil, Mobil 1 10w40 4T and Hi-Flo filter. This oil just flat works and shift quality does not fall off, period. This will be the third run with 10w40 4T, never ran any previous brand of oil more than one OCI. Finally settling in on what a good analysis looks like 🏍. Gotta go with what treats you right!
Sample heading off in the next couple days, will post up once it is done.
2016 FLSTC
out: Valvoline VR1 20W50 + HiFlo, Formula+ primary fluid, Redline Shockproof trans fluid
in: Valvoline VR1 20W50 + HiFlo, Belray primary fluid, Belray trans fluid
2009 Yamaha Tma x scooter 18890 mi
Out: Bike Master 10w-40 which is made by Bel Rey i think filter: Bike Master 2 inch filter
in: ultraLub10w-40 API S L Jaso ma Jaso ma2, filter: fram 6017A 2.5 inch
Rear chain bath Travellers 80w-90 gear oil
While off topic I sure miss the two stroke M.C.
2005 Ducati monster S4r, Valvoline Vr1 Racing 10w60 HF153 oil filter, total miles 33000 i change oil and filter every 3000 miles
10/07/2020
2016 Suburban 5.3
65,463 total miles on the suburban
14,236 miles on oil OLM at 10%
Oil AMSOIL Signature Series ASM 0w-20
Ea017
No noticeable oil consumption
Sent the sample off to Dysonanalysis to see how this sample did. This will be the second oil change at 14k.
10/07/2020
2016 Suburban 5.3
Ea017
Nice!
10/07/2020
2016 Suburban 5.3
Ea017
That is a weird motorcycle, never seen or heard of one of those.
Lol, I was gonna say the same! Last time I did something like that, the poster at that time told me to stop being a forum police. I said if I posted something for an F150 in a motorcycle forum, I would want someone to point it out in case I had made an honest mistake.
