Post Your Latest (Motorcycle) Oil Change!
Originally Posted By: ledslinger
1982 V45 Sabre, 23,600 miles. Had to dump a fill of Valvoline 10W40 Synthetic motorcycle oil at 600 miles due to poor shifting. I was afraid I was going to have to replace the clutch, which would have been a shock since I bought the bike new and the clutch hasn't been abused.
You've owned this bike for 33 years and have put less than 24,000 miles on it??
96 Sportster, 3 quarts of 20w50 and one quart of transmission oil,one chrome filter,3 gaskets, 50 bucks at the Harley store, am good to go. Have never had any engine problems with HD 20w50...
2009 V Star 650 Classic
Drained the mix of 2qts Valvoline syn 20w50 and 1qt Valvoline syn 10w40 (all MC oil)
Put in 1qt Mobil 1 15w50 and 2qts Mobil 1 V Twin 20w50.
My 2013 Yamaha Road Star 1700 . At 6300 miles 4 qts. Valvoline 20w-50 cycle oil non-synthetic . Changed at 2000 miles of use.Also a Microguard filter from O`Reillys .
My 07 Yamaha FZ1 was due for an oil change (but I left the Wix 51358 oil filter in for another OCI).
Out: Shell Rotella 15W40
In: Repsol Racing 10W50
I scored the Repsol oil at work for a screaming $2 per quart so I couldn't pass it up. Also decided to experiment by adding 2 oz. of MoS2 from Liqui Moly to see if the engine operated or shifted more smoothly; but haven't noticed any immediate changes (at least it was a cheap experiment to see if it was worth the hype and testimonials here on BITOG).
2011 BMW R1200R 25068 miles on bike
2qts each Valvoline VR1 Syn 20W-50 & 10w30. Dumped same mix @ 5028 miles.
Mann MW75 oil filter
Remembered the 24 quarts of Brad Penn I have had in my garage for some years so
out some generic 20W50 they use at the dealer
in Brad Penn 20W50
2006 Yamaha FJR1300
43000 mi on bike
3800 mi on oil
out: Shell Rotella T 15w40 & Microgard filter
In: Havoline synthetic blend 10w40 & Bosch Distance Plus filter
Motorcycle: 1986 Yamaha FZX700
Out: Castrol Actevo Part Syn. 10W40 and a HiFlo 204 oil filter.
In: Golden Spectro Part Syn. 10W40 and a HiFlo 401 oil filter.
OCI Mileage/Duration: App. 3,300 miles and 14 months of use
I don't normally use either Castrol or Golden Spectro but I received the oil for free from work so I figured I'd test them out.
Out: Whatever the dealer put in it when I bought it. And a HiFlo filter is being removed (Had to remove the HD one when I installed an oil cooler, installed a new HF one for the heck of it).
In: Mobil 1 15W-50, and another HiFlo filter.
2013 H-D Blackline
2006 Focus
Out: Maxlife 5w20 (5900+ miles,8mos due to medical issue)Removed Motorcraft FL400S
In: Maxlife 5w30
Oil filter Motorcraft FL910S
