Post Your Latest Coolant Change.
2007 Mustang GT Out- looked like the factory fill -only 13 years old
luckily only 55k on the odometer
In - 50% Prestone green 50% distilled water after a good flush using distilled water.
1998 Mustang GT. 4.6L 2V V8.
out: Ford Gold (i think)
In: ZEREX G-05 50/50 distilled water.
Had to drain the rad to do the oil cooler gasket leak fix. Got out a little over 2 gallons.
2003 Accord EX V6 - Timing Belt Service, Approx 1.5 gallons of Zerex Asian Blue to go with whatever Honda Coolant had been in there before. This will be the second coolant exchange for the car and everything still looks perfectly clean, no rust. ~229k on the car.
Typing that out made me curious, went and looked it up. According to the owners manual:
Total System Capacity: 2.2 US Gallons
But a 'Change' is 1.77 Gallons. So at 1.5 Gallons, I got at least 75% of it out. Good enough for me.
02 jeep grand Cherokee
4.0 inline 6
Water pump replacement
Out: unknown green coolant, qmi cooling system flush
In: 60/40 napa universal green and water, qmi cooling system conditioner
93 Chevy 1500
5.7 v8
Out: unknown, bg cooling system cleaner
In: 60/40 napa universal green and water, bg super cool
40,000 miles
OUT:
Whatever pink VW put in as new.
IN:
Distilled Water / G13 Pentosin E (60/40 mix)
2014 5.7L Hemi in a cop Charger with 100K miles on it.
OUT: 13 pints of coolant of unknown chemistry
IN.1: 1 quart radiator flush + 12 quarts tap water
-driven for 6 hrs-
-drained-
IN.2: 13 quarts distilled water
-driven-
-drained-
IN.3: 13 quarts Prestone Dexcool 50/50 coolant
'10 Toyota Yaris and '15 Toyota Tacoma.
Valvoline Zerex Pink out and Valvoline Zerex Pink in.
2011 Subaru Forester X 2.5 na
Out: Unknown green coolant
Flush with blue devil coolant flush blue bottle & distilled water
In: Zerex Asian Blue
In March 2020, I bought 2 gallons of the "NEW" PEAK 10 X Full Strength(non 2eha) at AAP which was on sale & I used my $peed Perk$ Dollar$ and there was also an AAP$10 rebate. This along w/ 2 dallons of Walmart distilled water .98¢/gal.
I mixed both gal's of 10X w/ 2 gal's distilled water to make 4 gallons of 50/50. This amount gave me enough 50/50 to do D&Fs on 3 vehicles including the overflow. I only did the 2(Alt/Civ) cars in my sig and still have ~ 5+ to maybe 6 qts of 50/50 remaining.
I believe that after all was said & done, each gallon(now-50/50) cost me in the $5 range.
1994 Freightliner cab over with 11.1 Detroit 735,000 miles
Out: no idea, was orange/red probably some form of ELC
Flushed with Fleetguard Restore
In: TRP 50/50 ELC
Also waiting on my parts to install a coolant filter.
2008 Ford Escape. The coolant was super dirty when I bought it and read online that these have a problem about that and also a problem with the water pump and it said if the coolant gets dirty fast again then the water pump was going out and the water pump on these is the silent killer so it’s important to replace it if they’re going bad. Used Prestone coolant.
2015 Cadillac SRX
Drain 'n fill:
Out: factory fill (looked pristine)
In: Dex-Cool (Valvoline Zerex) 50/50 w/distilled
