Post your latest brake job
Neighbor finally ordered the pads last week. I just got to it today. Now he needs to order the rear rotors also. Passenger side could be used but drivers side is quite gouged on outside. The outboard pad was on metal. Last place that did it I don't think cleaned and lubed the slides, they were like glue. Passenger side was missing the rubber plug to seal outside and bellows has a chunk out of it where it goes into caliper. I had to use the impact to get the caliper slide out. Luckily I had one of the rubber plugs from my old Sequoia in my brake-box-of-stuff. The old "grease" if you want to call it that was so sticky from water getting in there. Cleaned, wire brushed everything, got the rubber "tubes" out and cleaned them. The one on drivers side was twisted up and also causing binding. They also didn't put the swear sensors on the last set to help let you know they are getting low. I put them on the new ones and the worn re-using one.
I put 3 new Raybestos Element 3 pads on. Passenger side in and out, drivers side inboard. I took the pad that had life left to it and used it on outside, drivers side. I know I need to redo the whole thing when the rotors and new rubber boots come but at least he can get to work (NYPD) safely. The new pads will be fine to reuse with new rotors. Everything was moving nicely as it should.
Finally had a non raining weekend and schedules that matched up to put the new rear rotors on. One of the caliper slide pins was looking a bit ugly but I knew that would happen since boot was ripped. I had greased up as good as possible. It was still moving pretty good.
Didn't get any pictures this time but everything came off nice and easy. Put the new rotors on, replaced all the rubber boots/plugs. Cleaned up everything, re-greased, reassembled with pads from January except drivers side got the new pad installed that I kept in box so it wouldn't get destroyed on gouged rotor. The old original one that I put there took the shape of the gouges but was working fine and had life left still.
This one that had thickness and groove.
2015 Ford F-150
94k miles
V6 Turbo, manual parking brake
Off: original brakes, rotors, & brake fluid
On: NAPA premium rotors, SikentGuard pads, & flushed w/ Brembo DOT4LV
Original front pads were rusted to the brackets (passenger side), and one front slider pin was stuck in place (driver side). Rear brakes moved freely and were not totally spent, but this truck was essentially relying mostly on the rear brakes! Lug nuts were totally effed up and required a hammer to seat the socket.
Brake job from hell on our 2018 Grand Caravan.
Couldn’t get 2 lug nuts off, which resulted in the stupid decorative cap ripping off. Great… go buy an impact, they still wouldn’t budge. Go back to the store and get a blowtorch. VICTORY!
Caliper and brackets came off no problem, and the passenger side wheel was off in 10 seconds… but my god the rotors didn’t want to budge… more blowtorch it was and eventually got them off.
No idea what came off, bought it used in 2019 with 40k miles, now at 110,670 miles. Hopefully the fronts go easier…
Powerstop geomet rotors and ceramic pads went on.
View attachment 218886View attachment 218887
You got your money's worth... By the way, what's all that red stuff?
The aftermath of my boys learning several new swear words 😅
Here’s some bonus pics of the caliper bracket in case anyone was interested View attachment 218928View attachment 218929View attachment 218930View attachment 218931
Those brackets look a lot like the front brackets I removed from the F-150 (see the post above yours). I don't know if the guy drove into the intracoastal/ocean or what happened, but they looked like they were driven in the salt belt!
I also had two lug nuts that wouldn't succumb to the Ryobi impact (300 lb ft max). But if/when a lug nut doesn't budge, a 25" breaker bar (or shorter one w/ cheater) will always break it free. Those beauty covers are a PITA!
2016 Honda Odyssey off with the EBC green stuff elite pads up front and in with the TRW Pro pads. The EBC while they stopped good initially. They create dust at a rate that can not escape the pad chamfers and slot in middle so it makes a horrible grind noise at times but they also squeak like crazy.
2006 Toyota Tacoma, 2WD, X-cab, 2.7L.
I bought January 2020 with 111k miles.
145k on vehicle now.
Replaced front pads and rotors.
Off: Unknown rotors. Pads were WBR
I don't know what kind of pads they were, but I have never seen so much brake dust in my life as what they produced.
On: Import Direct rotors and Wanger OEx pads. Purchased from O-R. I paid an extra $10/rotor because they had a three-year warranty vs the typical two.
A few years ago, I put those pads on my daughter's 13 Corolla and was and have been impressed with them.
For mine, the pads were great, but the hardware supplied was junk, it did not fit properly. Thankfully the stuff on there was in good shape yet, so I cleaned them up and greased them.
The LF caliper had about a 1/32" hole in the dust boot. I figured it must have been from the prior brake job. They pinched the boot squeezing it back in or something like that. The piston moved freely yet, pads had nice even wear, etc. No road salt, no dirt roads; I left it as is.
Gonna do the brakes on my uncle's 2007 Pathfinder, was only around $220 shipped on Rock Auto for both sets of Wagner OEX pads and Raybestos Element 3 coated rotors all around. I had a Speedperk soon to expire so I bought a tube of silglyde, and one of the sets of pads has a small packet of moly lube in it, I guess I'll use that on the pad ears.
My daughter’s 2009 Camry.
Raybestos Element3 pads and rotors for the rear.
I drove up to her place at college and she did the work while I supervised and complained how nobody wants to work anymore.
Then she made me buy dinner.
Pricing from Amazon
Pads $36.54
Rotors $51.80 (2@ $25.90/ea).
$88.34 total not including incidentals.
Rotors and pads on all sides on the 05’ Xterra. Did them about 6 months ago. Been getting a squeal from them not sure if it’s front or back. It’s really noticeable in the morning. Pressing on the brake pedal slightly stops the noise indefinitely.
2021.5 VW Atlas.
3 years of tolerating a horrible brake squeal at low speeds. Dealer replaced rotors and pads, still came back.
Resched my limit after 2+hours in bumper to bumper traffic on a recent road trip.
Pulled off the factory rotors and pads.
Replaced with Centric high carbon coated rotors and Bosch quiet cast pads.
Squealing went away and has stayed away for several months now.
Here are the old VW rotors (15k miles on them. Ugh)
2021.5 VW Atlas.
Here are the old VW rotors (15k miles on them. Ugh)View attachment 224363
I had a similar problem (and a bad shudder) with Element 3 pads and rotors on a '15 Odyssey. Honda pads and high carbon rotors seems to have done the trick.
I probably could have just slapped some ceramic pads in place of the factory semi-metallics but I wanted to be sure - so I went with new rotors too.
Oh man, I've been hearing some issues on here with Element 3 pads, hopefully mine hold up. I've only put on 2k miles since the brake job 1 year ago, so we'll see
My guess is, the Element 3 rotors are not suitable for heavier vehicles or they changed the composition. Dunno, but I will not be buying any more. Disappointing.
