- Joined
- Aug 4, 2021
- Messages
- 1,366
I see, so a dedicated product for each task is best.I've always been a little leery about using something with that much graphite and moly in contact with rubber, but that's probably just me.
In theory, sure, it should do an acceptable job on everything, CRC certainly advertise it that way, but It'll never be as good as dedicated products for each task.
In practice? Well, Permatex uses similar advertising for their products...
So, say, the CRC for metal to metal moving contact areas, and Toyota (Cosmo Rubber grease0 on the slide pins going through rubber bushings/sleeves?
Is there an over-the-counter substitute for the Toyota (Cosmo Rubber grease0, or does it need to come from Toyota?
What do you think of the AGS SYL-Glyde for pins, rubber bushings/sleeves?
I take it I can't use that inside calipers and wheel/master cylinders though?
