Post pictures of your car's engine compartment
This is the 331 stroker that was in my '65 Mustang fastback.
Gone now.
Greg, Nice old Jimmy
Was there a strong family resemblance to a Chevy engine inside or was it a completely different design?
GMC engines for that era used high pressure bearings, had a full-flow oil system (not splash system) and a longer engine block.
If you tried to put a GMC motor into a Chevy truck, it wouldn't fit without cutting out the radiator.
91 dodge dakota with k-car 2.5 4 cyl engine about to undergo a redneck head gasket repair.
Lots of room for something bigger in there. :)
Ziptie the cam sprocket to the timing belt and remove, hang from a bungee cord so one doesn't lose timing. Lose the head bolts. Manifolds stay on the head. Both are on the same side. A jack goes under the exhaust and lifts everything an inch or two. Grab the old gasket and quickly wipe everything down with a scotchbrite pad* then slide a new gasket in.
This way you don't have to fight rusty exhaust manifold studs. On a mopar 2.2/2.5, the heads stay good most of the time but the gaskets blow fairly regularly. I was still driving the truck but getting exhaust bubbles in the radiator overflow, a sign of future trouble. Dragging a bed full of firewood etc around with that tiny motor I wanted it in full performance mode.
*evil b/c leaves little shards everywhere, but it works.
morepower, your engine looks oddly different than my engine, mostly on the left side. Do you have the VVT-i engine?
I'll post pics of my engine soon.
Gone now.
My, My, I like this one. Brings back fond memories.
